Question about Home
Nothing happens when foot button is pushed on the remote. The other settings work fine. Even when zero gravity button pushed the head responds.
The bed is an Ergomatic adjustable, about 10 years old The remote control says Ergomotion. It's looks like a Serra remote.
SOURCE: Innovage Jumbo Universal Remote Control
If you don't have the code do this! I worked for me.... Hold code search until light stays on... then select item to program <tv, vcr, dvd,exct..>... then press power button once... It will blink every couple of seconds and run thru the codes it self..... wait for the item choosen to turn off.... Then quickly press enter... TADA PROGRAMED!!!!! continue for each item to be programed. Be patient there are up to 500 codes! Can take Up to 10 min, But better than wasting $10.00$ good luck
Posted on Aug 04, 2008
  • 247 Answers
SOURCE: OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Posted on Dec 18, 2008
SOURCE: Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Posted on Apr 26, 2009
SOURCE: I can't get started.
We had the same problem. Turned out that if you have an original gamecube controller plugged in at the same time you are attempting to use the Wii remote it will only let you use the gamecube controller. Unplug the gamecube controller and you can now use the Wii remote. Or, you can choose to use the Gamecube controller. Both will work.
Posted on Jun 05, 2009
SOURCE: can't get my CyberHome CH-DVD 300 working
Check for bad capacitors on the alimentation fead target
Posted on Sep 01, 2009
I have a viper 7254v 2 way LED remote start and it locks/unlocks vehicle but it won't start the vehicle. I have tried taking it out of valet mode but that doesn't seem to do anything. When I click the...
This may sound funny but my mom has a brand new Lincoln MKZ and was having the same problem with her remote starter. What I did was, I pushed the lock button on the remote and then pushed the start button and it started . Even though the car was already locked for some strange reason she has to push both if she wants to start it remotely . I'm not sure why this happens and not sure if it will work with your remote but its worth a shot. Good Luck
Nov 02, 2017 | Viper Vehicle Parts & Accessories
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
No communication between receiver and remote
amandaharwoo,
The first thing I would do, if you haven't already, is replace the batteries in the remote. The lights will still illuminate if the batteries are low but won't perform the remote functions. If that doesn't fix the problem, the remote may need to be readdressed to the receiver. I have provided the steps below. If you have further problems, please respond to the site.
  • Remote: All Other Remotes
    1. Go to System Info screen
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button
    5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DSIH Network
Jun 13, 2010 | DISH Network 721 DVR Remote Control
My sonic riders won't recongnize my wii remote.
Try pressing the home button then press the wii remote settings then re sync your remote.
Feb 13, 2010 | Sega Sonic Riders: Zero Gravity for...
Bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Jun 26, 2009 | Sewing Machines
Multi player
Well: first. press the home button then go down and click wii remote setting s then click disconnect wii remote then both of you press the 1 and 2 buttons until it recognizes your wii remotes.
Feb 25, 2009 | Sega Sonic Riders: Zero Gravity for...
Jan 29, 2009 | Sega Sonic Riders: Zero Gravity for...
Garage door will not reprogram its remotes
Did you actually go to the power head and push the program button, then the remote button?
Is there a small wire hanging down from the power head? It's the antenna wire.
Jan 28, 2009 | Chamberlain 950CB Remote Control
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
