Question about Cell Phones
Fault code error 1110 on freelancer 1 2004 Says error unknown how do I fix
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
Hi i need unlocking code for nokia 1110 imei: 359766/00/176273/4
Hi, You can get the unlock code for a Nokia 1110 from www.unlocking4u.com/nokia-1110/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Nokia 1110,
1 - Switch on your Nokia 1110 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1110.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1110 would then display the message "SIM Restriction Off" and will be unlocked!
Sep 11, 2012 | Nokia 1110 Cellular Phone
Unknown Security Code
SET UI OPTION
ON FLASHING BOX.
Dec 07, 2010 | Nokia 1110 Cellular Phone
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
I need a security code of nokia 1110. so how i get it?
you can easily break the code of nokia 1110 because there is an technical error and it may not be solved as you hold the menu key and then press * button then you can unlock the code
Jun 02, 2010 | Nokia 1110 Cellular Phone
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Sharp AR-5132 has a U5 error code
Check and clean all the Sensor on the ADF!
Jul 07, 2008 | Sharp AR-5316 Advanced Digital Imager...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
