Question about The Office Equipment & Supplies
Error code sc 819 is indicated when start the operation. no answer is given to solve the problem. I pray your expertency to get solution.
  • 393 Answers
SOURCE: Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Posted on Jun 18, 2009
laseramp
  • 313 Answers
SOURCE: how can i solve the error code sc 92-01 and sc 21-06?
DescriptionService code SC21-06.Solution CAUSE: Wire cleaning abnormality.
SOLUTION: Perform the following:
1. Check the operation of M-10.
2. Remove the Transfer/Sep corona and check for binding of the cleaner.
3. Re-seat the connectors on the ADU driver board.
Posted on Aug 20, 2009
SOURCE: if i switch it on it starts warming shortly and
SC 391 development bias leak signal is detected.check drum unit and power supply
Posted on Dec 16, 2010
  • 67 Answers
SOURCE: como quitar el error sc
• Software application error
• RAM shortage
• HDD error (hard disk drive )
Posted on May 16, 2011
joel_baleta
  • 155 Answers
SOURCE: what should I do to
[Cause]
Dirty contacts on Upper Right Cover Safety Switches. Toner gets inside the Upper Right Cover Safety Switches, which can lead to lower DC voltage being applied to the Laser Diode. Which leads to:
SC 990 eng_procon.c (when a normal Grayscale pattern was not detected 15 times consecutively during ID Sensor Grayscale pattern check) check with SP 7403 Service Code History look for Detail in history of SC 990.
LD Power not being strong enough to be read by Laser Synchronizing Detector causing a SC 322 or 326 depending upon timing.
5vdc not being fully applied to connector 403 pin 3 on the Laser Diode PCB causing an Open Cover Indication, or 24vdc not being applied fully to connector 107 pin 2 on the PSU PCB causing an Open Cover Indication.
Circuit Explanation: 5vdc (VCCD)is output from connector 403 pin1 of the Laser Diode PCB where it travels through 2 of the Upper Right Cover switches than through 2 of the Front Cover Safety switches before being applied to connector 403 pin 3 of the Laser Diode PCB where it is now used to power the Laser Diode. Lower voltage on pin 3 leads to lower laser diode output which causes the machine to raise LD Power (SP 2-103) when maximum values are reached, laser diode output can not be increased further which can lead to SC 322, SC 326 and/ or SC 990 eng_procon .c. If the voltage drops too low an open door indication is sent to the BICU PCB but a signal is not sent to the IOB PCB which tells the machine which door is open.
Note: An older Drum more than 150,000 copies can also lead to SC 990 by causing incorrect ID Sensor readings
[Resolution]
1. Clean the internal contacts or replace Right Door Safety Switches (2 of Part Number 1204 2521 and 1 of Part Number 1204 2529)
Clean and vacuum the PCU.
Clean the Toner Shield Glass, Charge Roller and ID Sensor.
Check Service history for Drum Life, if over 150,000 replace Drum (Part Number A230 9510)
Reset SP 2103 -1 thru 4 to defaults.(LD Power Adjustments)
Reset SP 2001-1 to its default. (Charge Roller Bias Adjustment)
Execute SP 3001- 2 (ID Sensor Initial Setting)
Posted on Sep 03, 2011
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Model sp200s. What does c8 error indicate?
Fusing Reload Temperature Error (Fatal Error)
After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
There is a problem with the fuser section p/n M1014002 -Carl
Apr 20, 2014 | Ricoh Office Equipment & Supplies
Service Call SC819
I found that this 'SC 819' occurs if you use the bypass tray for the scanner. I found also that this error can be fixed with an firmware update. See link. http://www.copytechnet.com/forums/showthread.php/32934-Ricoh-Aficio-2035-SC819-Error-Code?p=132762&viewfull=1#post132762
I have no idea how to do that at the moment, and I can't report the success of this way.
Jan 22, 2014 | Ricoh Aficio SP C240SF
P0843
OBD2 codes,
D flash is in the operators guide, it says, bad tranny.
lost the guide? ive posted it 100 times now. the link, need it?
obd2 is easy P0xx codes are USA FED, spec codes ( a standard)
google is really your friend, 1st hit , bingo,
http://www.civicforums.com/forums/181-8th-9th-gen/351431-engine-ligh-flashing-d-p0843-what-do-next.html
overwhelmed, ? yes, A/Ts are on the extreme complex side.
ask any ASE badged mechanic, for help.
the dealer will be (stealerships) like $6000 fix, 1/2 tranny and 1/2labor.
btw 1:
if tranny slips dont drive it, or the costs to fix rise fast.
as you can see, it can be
1: bad wires.
2: bad sensor.
3: bad transmission.
only testing finds the cause, and wire inspections and maybe new sensor and pray.
what skinflints do (or just smart) is reset it (OBD2 scan tool reset) and see if it comes back , praying its a 1 time ever error. this decade.
see>? this is true with all DTC'S, reset and pray.
or in the case of 455s tighten the gas cap,reset and pray.
DTCS are errors. (onboard, diagnostic monitor errors)
Dec 14, 2013 | 2004 Honda Civic
While trying to print, my Gestetner DSc435 is displaying a functional probelm sc560.
Some expert may give the exact answer but according to my knowledge SC 5XX error code series indicates a problem in fuser or paper feeding sections.
Aug 29, 2011 | Ricoh Aficio 450 Copier
Como quitar el error sc 819 de una ricoh 3025
• RAM shortage
Apr 06, 2011 | Ricoh Aficio 3025SP Copier
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
24 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
