Question about PRINTER Office Equipment & Supplies
Hi, I don't have a printer and need a returns label please thankyou.L Abbott.
Light is blinking and won't print labelsbet
If you like my solution, please give me 4-thumbs up rating.
Why is the light on the front of my Model 330 LabelWriter blinking?
There are 5 possible reasons for this:
  1. The labels are not left-justified
    • Verify that the labels are left justified and loaded properly in the LabelWriter. Click here for more information on loading the labels in the LabelWriter.
  2. There is paper dust or a piece of a label blocking the sensor
    • Take the roll of labels out of the printer and use the provided cleaning card to clean your unit. Click here for more information on using a DYMO Cleaning Card. You can also use compressed air by blowing some air along the left side of the paper path inside the printer.
  3. The labels you are using do not have the index marks properly cut out between each label
    • If the index holes are not cut cleanly, you may run into this problem. Try a different roll of labels.
  4. You are not using DYMO labels
    • If you are not using DYMO labels (or are unsure whether or not you are), please obtain a roll of DYMO labels and try to print again. DYMO labels are made specifically for our printers.
  5. The photo sensor that reads the index mark has failed
    • If this is the case, the unit will need to come in for repair. Select the Ask A Question tab at the top of this page to contact our Technical Support team. Please include the following information so that we can set up a Return Material Authorization (RMA) for you:
      • Full Name
      • Full Shipping Address (No PO boxes)
      • Phone Number
      • Date of Purchase
      • Model Number (a 5-digit number found on the bottom of your LabelWriter)
      • The 11-digit number under the barcode on the same label
      • Serial Number (located on the bottom of the printer, starting with "S/N" -- it also contains a dash after the first five numbers)
      • If your unit is out of warranty (beyond 2 years from the original date of purchase), please provide us with a method of payment (including expiration date, if using a credit card). The cost to repair your unit is either $75, which includes UPS Ground return shipping, or $90 for UPS Next Day Air return shipping. Please let us know which return method you desire.
Aug 04, 2011 | Dymo LabelWriter 330 Thermal Printer
Need return address
return label will be either in ur mail or either it might have *** @ ur place through regular mail.contact kodak@ 1800 421 6699 for further assistance
Jul 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing problem
Problem has been solved, thankyou,
Printer was unistalled and then re-installed.
Jul 22, 2009 | Citizen CLP-521 Thermal Label Printer
I have this EZ label printer (says Label IT! and KL 780). It has worked before to make simple labels, but now when I try to print anything-anything at all- 'data error' comes up on the screen. What do I...
Hi. I can help you. Remove all of the batteries. Let it sit for two minutes while it resets. Reinstall the batteries being careful to honor the polarity. Turn it on and you should be up and running. If you still have the problem return it.
Jul 13, 2009 | Casio KL-780 Thermal Label Printer
Kodak 5100 Printer Return Shipping Label
Hello C_Lopez,
As long as you receive the printhead, there's no need for you to return the defective printhead. But just to make sure, call kodak technical support: 1-800-421-6699
I hope I have been some of help...
Nov 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Shipping Label
I would call them up just to make sure...chances are if they did not send you one they don't want you to send it back. But just to be safe give them a quick call, better to be safe then sorry!
Oct 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error
turn off your printer press PRINT & ESC at the same time, prees on/off at same time then release the PRINT & ESC botton then press SET
Apr 27, 2008 | Casio KL60SR Label Printer
NO COMMUNICATION
hi i have zebra z4m plus printer when i give them command for printing it's not printing and i need a solution can you please help me thankyou
Apr 10, 2008 | Zebra Z4Mplus Label Printer
Compatible ink
Hi, sounds like a faulty ink cartridge, we get this now and again with selling compatible ink cartridges i suggest taking it back to the shop for a replacement wont be the printer as long as its fitted correctly with label removed..
Happy New Year
John
Dec 17, 2007 | Epson Printer
21 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
