Question about Retail Supplies
I need my tax nr - Retail Supplies
How to program two non cumulative taxes on a Casio PCR-T2000A?
Firstly, change the rates for each tax in the tax rate setting tables of your manual. Then you need to turn on tax rate 1 and 2 for departments that need both. This is done in the department programming tables. Tax setting can be quite involved so follow the tables carefully.If you need a programming manual, One of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Dec 31, 2012 | Casio Parts Cash Register PC Desktop
I just bought XE-A402 cash register how do i set just one depart ment as no tax, for labor
You need to check the tables in the department programming section of the book. There will be a setting for tax or non tax for each tax number. So if you need to turn off tax 1, set tax 1 to non tax. See how you get on.
If you need a manual, C-tech have one here:http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A402_operation_manual.html
Nov 20, 2011 | Sharp XE-A402 Electronic Cash Register
What is mean by tax and service tax
TAX:
A fee charged ("levied") by a government on a product, income, or activity. If tax is levied directly on personal or corporate income, then it is a direct tax. If tax is levied on the price of a good or service, then it is called an indirect tax. The purpose of taxation is to finance government expenditure. One of the most important uses of taxes is to finance public goods and services, such as street lighting and street cleaning. Since public goods and services do not allow a non-payer to be excluded, or allow exclusion by a consumer, there cannot be a market in the good or service, and so they need to be provided by the government or a quasi-government agency, which tend to finance themselves largely through taxes.
SERVICE TAX
Service Tax is a form of indirect tax imposed on specified services called "taxable services". Service tax cannot be levied on any service which is not included in the list of taxable services. Over the past few years, service tax been expanded to cover new services. The objective behind levying service tax is to reduce the degree of intensity of taxation on manufacturing and trade without forcing the government to compromise on the revenue needs. The intention of the government is to gradually increase the list of taxable services until most services fall within the scope of service tax. For the purpose of levying service tax, the value of any taxable service should be the gross amount charged by the service provider for the service rendered by him.
Aug 25, 2010 | Tally Computers & Internet
I have a compaq presario cq50 215-nr. the lcd screen constantly flickers with colored lines going top to bottom. I can work if I press the screen down. I called HP they say that this comes under accidental...
I am sorry to tell you that the screen has been damaged and will need to be replaced. There is no work around/solution for a bad screen. Replacement is the only way to go. Sorry.
Sep 06, 2009 | Compaq Presario CQ50-215NR Notebook
Change the tax rate on calculator on MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Mar 23, 2009 | Casio Office Equipment & Supplies
Oven will not heat after self cleaning
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Dec 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Apr 18, 2008 | Casio Parts Cash Register PC Desktop
Retail Supplies Logo
32 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
