Question about Liebherr Refrigerators
My Liebherr CNes 3366 fridge freezer has started to build up ice in the bottom of the freezer. How do I check the fan in the fridge is working, (I never see it going)as it may be the cause? thanks r
    Top Expert:
  • Liebherr Master
  • 12,744 Answers
Remove cover and test with a meter or push door switch when door open and should hear fan hum or feel air when door open fan stops unless you push switch
Posted on Apr 20, 2017
Liebherr refrigerator freezer model # cs 1601 79-362-3844 index 101/237 had an inch thick of ice on the bottom. I turned it off using the on/off switch for the freezer and left the refrigerator on.
Is the fan running inside the freezer? To see that you have to remove the back panel of the freezer. Also how much stuff are you putting into the freezer please make sure you are not blocking the vents inside the freezer. Also when you remove that back panel ensure the vent tubes to the fridge area are not blocked.
Jul 06, 2017 | Refrigerators
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
Alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Mar 01, 2010 | Liebherr Refrigerators
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
The fridge section is working perfectly well, the freezer section is not iced up, and the top two drawers are not working properly. The bottom drawer of the Freezer is working ok
suspect the fan is not operating.
take back panel off inside freezer. make sure fan can rotate freely. you may find it jammed with ice build up and if so melt ice off with a hairdryer. if the ice build up is extensive, get back to me.
also check continuity thro the fan motor and check for a supply to the fan motor. on some models, the fan will not start till the evaporator is down to temp so you may have to wait for 15 mins or so till fan starts
Oct 16, 2008 | Bosch Refrigerators
Fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Jun 23, 2008 | Electrolux ERN2820 Bottom Freezer...
Liebherr CNES 666 freezer - loud fan (?) noise
AbiH, the likelihood of frost inside the fan housing is high. You should manually defrost the unit. Unplug and use a hair dryer to melt as much water as possible. Be aware that hair dryers and water do not mix well! If it happens again, you may have low gas and require a service person.
May 26, 2008 | Freezers
Refrigerators Logo
91 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
