Question about Cell Phones
My LG3200 freezes up at the Telus screen. The screen is initially bright and then dims, I assume due to 'inactivity'. This happened once before. I had to remove the battery to get it to respond again. Now it doesn't seem to matter what I do. Is there anything I can do about it? Maybe some kind of hard reset? Thanks
My ZTE max blue locks after 15 seconds of inactivity,,,I tried everything I can think of without luck. PLEASE HELP!!!
Did you change the setting for the length of the inactivity timer?
Page 95. They call it Sleep Timer
Display
Brightness level:
Set the brightness of the display.
Adaptive brightness:
Automatically adjust screen brightness.
Wallpaper:
Select a background image or animation for the home screen or lock screen.
Sleep:
Set the length of time of inactivity before the screen turns off automatically.
Daydream:
Manage the Daydream function. When Daydream is enabled, photos or
animations will be displayed as a screensaver.
Font size:
Set the font size of the text on the screen.
Auto-rotate screen:
Select whether the screen contents should rotate when the
phone is rotated.
Pulse notification light:
Flash the backlight on the H
Here is your manual
https://s3.amazonaws.com/tpassets.devicebits.com/development/550da35452414173bf46cc48bc8edc87/manuals/02_09_2017_Z986DL_UM_EN_Final.pdf
May 18, 2018 | ZTE Cell Phones
What is the correct way to replace the watch battery?
turn it over and try again. the battery that is
Aug 15, 2015 | Watches
SONY VAIO PCG-61611l has a very dim screen
Normally, this is in part due to you not replacing it with what should've been an LCD. The reason why it's dim is because those diodes are not getting the required voltage to emit as it should. LCD's work under a different concept where crystals use the light modulating properties of liquid crystals. Liquid crystals do not emit light directly as LED's, because it stand for light emitting diodes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cesar_16d20d38798d492f
Mar 25, 2013 | Computers & Internet
Curve 8520, I've had an intermittent problem that the trackpad will not scroll. I can still use it as a button, and get in to perform most tasks with the keyboard, but I can not scroll through icons. ...
I'm afraid the track pad has to be replaced. It goes to full bright from dim screen when you touch it. that's because it sense the touch.but can't sense the direction(scrolling).
But, before that, see if a master reset works. Backup everything before that though
Jun 08, 2017 | RIM BlackBerry Curve 8520 Smartphone
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
Dell inspiron 5160 is dim.
This problem can also be due to the corruption of display drivers// assuming that you have checked the contrast and brightness do this step:- goto device manager// click on the display adaptar + sign and on the pop-up driver right click and select uninstall//
once the driver is uninstalled then restart the computer and check//
if that doesnot work then you can also upgrage the grafic card by going to the web site// even if this doesnot work then 100% the problem is with the notebook screen// contact best buy or wallmart or the retail store from where you have bought the notebook//
Jul 01, 2010 | Dell Inspiron 5160 Notebook
Screen troubles
I assume you are running it under normal power supply (mains)?
Try checking your display settings, they may be set st a lower brightness level. As you switch on the computer it is taking a few seconds to catch up and dim down once the settings kick in.
Aug 26, 2008 | Compaq Presario R3000 Notebook
Monitor is too bright
Lcd monitors do not go overbright due to aging,they may go dim due to backlight aging.Do front panel controls work and if so what happens when you try to bring down brightness?
Some monitors have a "Recall" function which is a factory restore bringing all setting to factory value.
Try this if available.
Samir
Mar 07, 2008 | Gateway FPD1760 17" LCD Monitor
Too bright
I just bought an Acer 19 inch this morning and I am assuming you have the same controls on the bottom of monitor. On mine I push the menu button twice....the left arrow once to select the brightness slider.....push the menu button again to turn slider red and active...then use your left or right arrows to adjust brightness...afterwards you use the menu to get you back to the exit button and that's it....I hope Don
Dec 07, 2007 | Acer AL2016W 20" LCD Monitor
Cell Phones Logo
110 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
