Question about Tablets & eReaders
My tablet came with a DC charger but it does fit it very well. where can i get another one?
    Top Expert:
  • Tablets & eR... Master
  • 12,744 Answers
Didnt specify unit --generic answer look on line using make and model of tablet or go to an electronics store with same information
Posted on Apr 20, 2017
Why after getting a brand new tablet right out of the box would a charger not work? This should not be
hmm seems strange but it sounds like the charger came dead on arrival depending if it charges by USB any type of USB charger will work even your computer can charge it unless it comes with a different type of charger a multi switch charger may work as long as your set the voltage down to 5v DC or in some cases 3.5V DC
Feb 26, 2017 | Tablets & eReaders
My hipstreet pulse 5v charger broke & i have bought several 5v needle chargers that plug into my tablet but wont register or connect to charge it why?
Hi yes the problem using different chargers polarity can be positive & negative. On the male plug or it can be negative & posative ....also they can be AC CURRENT OR DC CURRENT U NEED A MULTIMETER TO TEST THEM ...OR ITCOULD BE a fault with the tablet or the Charging socket .,cheers
Jun 22, 2016 | Tablets & eReaders
How do I get my tablet to turn on
It sounds like it may not be fully charging.
If the port on the tablet is loose/damaged or the cable/charger is failing, then the tablet may not be charging even though its plugged in.
If you can, try a different cable.
Make sure the charger is the correct one for the tablet! Some tablets require more electrical current then a computer's USB port provides. Same thing applies if you are using a 'phone' charger with the tablet, might not be enough current.
Most USB ports/chargers output about 5 volts DC (direct current), but they can vary in the amount of Amps (A) or mili-Amps (mA) they produce.
FYI - the symbol used to represent Direct Current is straight horizontal line with a dashed horizontal line directly under it.
Most computer USB ports only produce 500mA.
Most phone chargers only produce 1A.
Many tablets require 2.1A or 2.4A to properly charge.
Check with your tablet manufacturer to find out what your specific make/model requires and the look closely at the charger you are using to see what the OUTPUT is ... e.g. 5.2V 2.4A
Mar 29, 2015 | Lenovo S5000 7" Android 1GB 16GB
What output volt and amp USB charger should I buy?
afunta.com
What does the manufactor recomend?
Jul 02, 2014 | Afunta
Which is the amperage of the charger for the Prestige Pro 7 tablet?
you need a 5 volt 2 A power supply with a micro DC connector
Jun 06, 2014 | Visual Land Connect 7" Tablet
My Kocaso M1062 will not take a charge and says connect charger.
The power Cell (Battery) no longer accepts a charge. The exception is if the AC/DC charging adapter has failed. See if you have a similar power charger around the house. Look for the same type of male pin and proper DC or AC Voltage plus Amps as listed on the current Tablet Charger. Never leave chargers in the electrical outlet alone as they can be damaged by surge power. Try another charger and if that fails also, the power cell in the tablet needs replacing.
Dec 19, 2013 | Kocaso Tablets & eReaders
Blackberry tablet no power
You need a Blackberry charger. Other chargers might fit in the slot, but won't charge your device. You have to use (buy) a fast charger if your tablet is completely discharged and won't turn on. They're about £20 but worth it to keep using your Playbook.
Sep 22, 2013 | RIM Blackberry Playbook 7Inch Tablet...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
