Question about GE Dishwashers
How do I know if my ge pots rubber 600 needs a new drain solenoid or float switch?
4 Suggested Answers
SOURCE: GE front loader door switch wiring issue
Although there aren't any parts available for them these units ARE repairable. There are places along the sides of the case to unsnap the halves. Just be careful not to unload the spring inside
Posted on Dec 26, 2007
stewbison
  • 577 Answers
SOURCE: pump running continuously, Yes there
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Posted on Aug 21, 2011
  • 34733 Answers
SOURCE: I need a new upper and lower rack for GE Potscrubber 600
Appliance parts supplier
Posted on Sep 20, 2012
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
I have a Hoshizaki KM900MRH ice maker. It will run fine for a couple days then shut off and beep 3 times within 3 seconds. I am told by tech support that it could be a float switch. Where is the float...
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Power works no water into unit
hELLO THERE:
If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 19, 2010 | GE Dishwashers
Does the GE Nautilis have a water solenoid valve?
Yes and it is item number 744 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218471&diagram_id=22281725#d22281725
Close up:
http://www.appliancepartspros.com/part_details.aspx?part_id=2039343&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5218471%26diagram_id%3d22281725
And controlled by the float switch in the front left corner of the tub. If the float sticks there will not be any water supply.
Item 302 of the first link is the float dome and item 305 is the float. Don't be afraid to check to see that when the float is lifted up and down you hear a micro-switch click.
Thanks for using FixYa.
Kelly
Mar 14, 2010 | GE Nautilus 24" Built-in Dishwasher
We have a multi-family home and all units have new Nautilus GE dishwashers. Our second floor tenant is complaining of water not getting into the unit. We have tried unsuccessfully to figure out the...
There are two reasons that may cause the water not to enter the unit.
  1. Water-inlet valve. It lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
  2. Float switch.It is a small electrical switch located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Oct 08, 2009 | GE Dishwashers
No Water
The first thing I would check is the water float. The float is located on the bottom left front of the dishwasher floor. You will see a float cover, remove the cover and make sure the float moves up and down with your fingers. It should move freely.
If the float appears good, you will have to remove the lower kick plate. Behind the plate you will see the float switch and the water fill solenoid valve. With a volt/ohm meter you can check the float switch and water fill solenoid for proper resistance.
If you feel you want to persue that, we can get more specific about resistive values.
Let me know.
Regards,
Aug 13, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher gsd2200g00ww water supply valve
dishwasher g e model GSD2200Z00AD WON'T DRAIN WATER
Jul 18, 2009 | GE Nautilus 24" Built-in Dishwasher
No water to dishwasher
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Feb 10, 2009 | Dishwashers
Water will not pump in .to the dish washer
Water-inlet valve
Float switch
Drain line/air gap
Pump
Belt
Motor
Timer
Feb 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
