Question about The Computers & Internet
My fs6525mfp is always on the sleep mode how to remove it
How do you use the bypass tray on a Kyocera FS6525MFP ?
All the information for your product can be found here, including documentation, drivers, etc.
Hope this helps, Nik.
Jul 14, 2015 | Kyocera Ecosys FS-6525MFP Laser...
Why and how does my fitbit flex go into "sleep mode?"
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
Jan 11, 2015 | Fitbit Flex Wireless Activity & Sleep...
Turn sleep mode off
Go to Settings. Tap on Display, then tap on Sleep. Select a screen timeout duration.
Jul 26, 2014 | HTC Desire Cell Phone
How to solve acer monitor sleeping issue?
Press left mouse key and wait 10-15 seconds. Black screen and orange light is caused by computer going to sleep. Adjust your power mode.
Apr 30, 2014 | Computers & Internet
Msi sleep state appears stuck
Remove ALL media, DVD, CD, USB, unplug, remove battery, plug in reboot. OR try to boot to safe mode, open the Control Panel, select Power Options, set to High Performance, Change Plan settings, set SLEEP and Hibernate to Never.
Apr 18, 2013 | MSI L1350D-1672US Netbook
Wireless disconnect in sleep mode?
I think that is normal to conserve energy. There are times when it will take the network connections down to conserve energy.
If it is a problem you can always increase the time on the sleep mode or set it to NEVER.
May 13, 2012 | Dell Computers & Internet
Sleep mode is blinking. i cannot restart
Have you tried holding the power button for a few seconds till it restart. If that does not work try removing the battery. Once you get it started go to power options and turn off sleep mode and hybrid sleep under advanced settings.
Thanks for using FixYa
Jun 30, 2011 | MSI Computers & Internet
Emachine sleep mode
Try going into your cmos settings at system boot (usually hitting delete or F keys, funtion keys as your computer first turns on). Check to to see the boot sequence and look for sleep mode settings. If there isnt an option there, boot your system in safe mode and check through your windows settings for sleep mode settings.
Dec 18, 2008 | E-Machines emachines (emachinees) CD-ROM...
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Computers & Internet Logo
32 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
