Question about Mitsubishi Televison & Video
My screen on my mitsubishi 1080p. is too wide. only because it won't let you see all the letters when you are trying to search. model number.. lt -46133
  • Ron Hoffman
    Ron Hoffman Apr 20, 2017
    Did you try to adjust the format of the display? Click format on your remote. It should step through several different display formats that expand, zoom, narrow and show standard sizes. This should solve your problem.
4 Suggested Answers
SOURCE: White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Posted on Apr 25, 2012
  • 1238 Answers
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 19, 2012
  • 75017 Answers
SOURCE: I have a mitsubishi lt-46133 with fast blinking blue power light on. It will not turn on.I have some electronic know how. Any ideas?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jun 09, 2016
I got a free mitsubishi lt-46144 yea! at thrift shop as is there are pencil colored vetical lines down screen is worth trying to fix
If you wish to get some details; check the site linked here. Pull up older posts. Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 30, 2016 | Mitsubishi Televison & Video
My tv want come on at all but it was working fine this morning
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV, Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV (2011 Model): Electronics. ... The Federal Trade Commission (FTC) wants you to know that the ... It is in fact much brighter than my 82" set which also has a 180 watt lamp. ... any lightcoming in; it will cause rather bothersome reflections off the TV screen.
Mitsubishi WD-92840 92-Inch 1080p 3D Projection TV ...
Dec 26, 2015 | Mitsubishi WD-92840 92-Inch 1080p 3D...
I am getting wide lines of bars on the screen after replacing dlp chip in wd- 73735 73" mitsubishi
you will need to pull the DLP chip out & clean the dust & foreign particles that got in while you had it apart.
Mar 11, 2015 | Mitsubishi WD-73735 73-Inch 1080p DLP HDTV
I want a motherboard jumper setting table
You'll need to open the case on your PC; locate the manufacturer name and model number of the motherboard and then use an online search engine by typing in <motherboard> (without the arrows) with the model number. You should be able to find a manual from third party sources or by going to the manufacturer's website to see if the manual is archived.
You can locate the MOBO information at either one of these locations:
  • RAM slots
  • CPU socket
  • or between the PCI slots
MOBO model numbers are usually a collection of numbers and letters between 5 and 7 digits long.
If you have a problem located the model number and manufacturer:
Run the utility; depending on the speed of your processor, it could take seconds or about a minute to pull up the info. <Click> on the mainboard tab, it'll list the manufacturer's name and model number of the MOBO.
A third way to locate MOBO information, Open the <RUN> dialog box from the start menu or by pressing the windows icon key and the letter R simultaneously.
Type <MSinfo32> (without the arrows) and press <enter>
The BIOS ID will be displayed- sometimes manufacturer info and model number will be displayed.
If not, you will be able to determine the BIOS as being either AWARD or AMI (American Megatrends, Inc.); and from there, be able to decode the ID number to a specific manufacturer.
  • AWARD: first five digits indicate the chipset & the following two digits identifies the manufacturer; you'll have to go online and search who that two digit manufacturer is.
  • AMI: the MOBO manufacturer is Identified by the last four digits in the third group of numbers.
Mar 04, 2015 | Acer Veriton M480G-EQ8400C Core 2 Quad...
How do I get the keyboard to type in youtube search engine (browser) on my Lg smart tv?
As of right now youtube doesn't recognize USB keyboards. They are coming out with update to fix it.
Jul 24, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
I need a 73' tv screen for a mitsubishi model wd=73638
Contact the authorized service center for Mitssubishi. It can't be purchased from open electronic spare part market.
Electro help
Jul 20, 2014 | Mitsubishi WD-73638 73 inch DLP 1080p...
How do you reset an 82 inck Mitsubishi 1080p tv
It depends which model.
A very common one is Press remote <MENU><1-2-3><ENTER
Mar 01, 2012 | Mitsubishi Televison & Video
I am looking for the Manual for the Samsung Plano TV Model: CS21M16MJ. Can you please assist. Many thanks,
Hi Colleen,
There seems that there are 5 models of the CS21M16MJ the other 4 have some extra letters after the model number you gave.
If there are no extra letters after the model number you gave then please ---> Click Here <---- to download your manual, if there are extra letters after your model number then please ---> Click Here <--- to choose the right model for you.
You will need Adobe Acrobat Reader (PDF) to view the manual if you dont have it you can download it free from ---> HERE <---..
Hope this helps. (: Please don't forget the thumbs up if it did :)
Feb 24, 2011 | Televison & Video
Green band
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Televison & Video Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
