With my application proccess - Computers & Internet
What should I do when my application is nt proccessed but keep on loading for ever
Uninstall in control panel. Then reinstall app and reboot Windows
Nov 01, 2016 | Computers & Internet
When i boot the computer no icons appear on screen
If you boot your computer, and after loggin in you receive a Black Screen but are still able to see the mouse move, try bringing up your tsk mngr (Ctrl+Alt+Del) then go to proccess' and click end proccess on explorer.exe then go to applications and press new task then type in explorer.exe, this should solve the problem, if not then I am sorry, that is what solved my problem.
Feb 11, 2011 | Acer Aspire 3690-2196 Notebook
SOME TIME THE NET IS PROCCESSING IN MY MOBILE, BUT SOME TIME IS NOT PROCCESSING. WHAT IS THE REASON OF THESE CONDITIONS
Sometimes When u open your net it dosen't opens because the server is down, ifu try after sometimes it will open...
Thank You for using Fixya
rupesh kumar
Mar 02, 2010 | Cell Phones
I have a problem that is hard to solve and all it is, is this window that keeps poping up, its an error report and if I click send error report it has to restart the computer and it gets really annoying...
First, run windows updates.
Type this on the address bar of internet explorer.
http://www.update.microsoft.com/windowsupdate/v6/default.aspx?ln=en-us
Then after you do all updates, download and run the free malware bytes version and run a full scan. This software is free to run but if you want the full version it will cost around 30 to 40 bucks.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
This should help you update the hardware drivers for you computer and also eliminate any spyware that may be using up your memory or making your computer work harder than it should.
Hope this helps!
Nov 08, 2009 | Dell Inspiron E1505 Notebook
Screen blanks out after a few seconds. If I turn
Fixya:
My IE 8 loads the correct odds on the tote-board and then suddenly the odds go blank.
I have to click down to another track and then click back up to get the odds working again.
The issue happens again at another track that I click on. Forces me to go through the same proccess over again.
This bug related issue is very aggravating so if there is a fix I would appreciate it.
oppusone
My IE 8 loads the correct odds on the tote-board and then suddenlly the odds go blank.
oppusone
oppusone
oppusone
Aug 31, 2009 | AOC LM720 17" Flat Panel LCD Monitor
Had not used it for a while.. put in new ink..even after several cleanings..it wont even print out a thing
Head cleaning is mechanical proccess, printing is electrical proccess. If nothing at all ink out/spray from head in printing proccess, problem with electricity. Damage board or short circuit at head cable. Check board first, may be some component "burn".Better to take printer to epson service center. Damage board can be replaced, but it must to check the cable head and small circuit at head first.
Aug 17, 2009 | Epson Stylus C84 InkJet Printer
I have an epson stylus r 1800 printer; the driver head is moving like it's laying down ink but none comes out on the paper. i have tried cleaning the heads etc via the maintenance option and that doesn't...
Aug 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
My computer proccess very slow what I can do.
The first things o do is to run a disk cleanup and defrag. Both these tools are located in your start menu under accessories>system tools. Once you have this completed and reboot you should notice improved performance. Hope this helps.
Jul 18, 2009 | HP Pavilion dv1000 Notebook
AT&T Tilt Smart Phone usb drivers license scanner
Well I'm sure there is barcode scanner application. Try SPB Software, Handango.
May 30, 2009 | Cell Phones
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
