Question about home Audio Players & Recorders
Setting up my home radio - home Audio Players & Recorders
Can regent home theater system modle ht-2004 pick up radio signals or cb radio waves.
Most audio equipment will pick up radio waves of various kinds. The question is do you want it to?
If as I suspect you don't then you have a problem. You can get special filters that connect between the aerial plugs and the receiver. These are set up to remove CB radio signals. Your local electrical parts shop or aerial installers will stock them. Also fit cable connections that are good quality, designed with high quality screening built in.
Apr 14, 2015 | home Audio Players & Recorders
I found this one at Goodwill and have no expeirenc ...Can it be installed in the home or does it have to be in a car or truck?
Any cb can be installed in the car or home. In order to set your radio up for the home you will need a 13.8 volt 7amp Power Supply and a good base antenna.
Jul 19, 2011 | Cobra 19 Ultra II CB Radio
Pioneer GEX-INNO2BK XM Radio Receivers backight problem
Have you tried changing the backlight controls in the menu? Pull up your menu, go to settings, then preference, and change display. Choose backlight display. You can put it always off, always on, or on for however many seconds.
Jun 05, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
What frequency should car radio be on to access xm
Go to your radio's MENU and set a frequency, then set your car to the same frequency.
Apr 24, 2010 | Delphi Roady XT XM Radio Receiver
I cannot get the radio to work
When you say "radio" I'll assume you mean the FM radio; perhaps the AM does work? There is usually a coax connector for the FM radio antenna, perhaps one was included with the set, perhaps not. Make sure it is installed properly. Tune your radio to a frequency that is local and that you can get easily with other radios in the house and car. If its not picking up that station, check your settings on the unit to see if there is something preventing reception.
Apr 11, 2010 | kawasaki 5-DVD Home Theater System - 1152...
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Feb 19, 2010 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Audiovox Xpress XM Radio Home Dock Problems
home dock does not allow the fm frequency generator. it only works in the car dock
Nov 18, 2008 | Audio Players & Recorders
Delphi MyFi SA10113 XM Radio
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Set the clock
You are in luck. I had to replace the batteries in my DWS-150 & couldn't find the instruction manual to reset the time. Fortunately, I remembered a while back I had the same situation & thought I might have downloaded the manual - while it was still available. Ifound I have it saved as a pdf file on my pc. Here are some excerpts: About the Atomic Clock The National Institute of Standard and Technology (NIST) in Fort Collins,
Colorado broadcasts the time signal (WWVB at 60kHz AM radio signal) with
an accuracy of 1 second per every 3,000 years. The signal will cover a
distance up to 2,000 miles from the source. Like a typical AM radio, your
Atomic Clock will not able to receive the WWVB signal in places
surrounded by heavy concrete or metal panels. The reception of the time
signal can be affected by mobile phones, TV, electrical appliances or other
electronic interference. To get the best performance of the Atomic clock,
please install the home receiver near a window and away from large metallic
objects. If the unit is not working properly, change the unit position. There
may be some interference at this location.
7
DWS-150-IB SP\ENG 10/12/04 11:30 AM Page 7
SETTING TIME
RADIO-CONTROLLED CLOCK
The home receiver will start synchronizing the clock after the 1st channel of
the RF thermometer is registered.
1. At normal mode, hold the “ - ” button located on the back of the home
receiver for 3 seconds to force synchronization.
2. The antenna icon will appear during the synchronization process (on the
right side of the time display).
3. If the icon disappears afterwards, radio time signal is not available at that
moment. Try setting the home receiver in other locations. Remember to
place the unit away from sources of interference such as mobile phones,
appliances, TV etc.
4. Antenna icon will appear on screen if the radio time reception is
successful. The radio-controlled clock will have a daily synchronization at 1:00 am everyday. If previous attempts of reception were
unsuccessful, the home receiver will attempt synchronization
each hour until successful.
5. Each reception cycle is minimum 2 minutes and maximum 10 minutes.
TIME ZONE SELECTION
Press “ - ” button on back of home receiver to select from the following time
zones in the U.S. (zone is displayed in the upper right hand corner of time
display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Time
MANUAL SETTING FOR CLOCK & CALENDAR
1. Hold “SET ” button for 3 seconds to enter clock set.
2. First, select 12 hour or 24 hour setting using the “ + , - ” buttons located
on the back of the home receiver. Press “ SET ” button to confirm.
3. Select Hour - Use the “ + , - ” buttons located on the back of the home
receiver to adjust hour setting. Press “ SET ” button to confirm.
4. Select Minute - Use the “ + , - ” buttons located on the back of the
home receiver to adjust minute setting. Press “ SET ” button to confirm.
5. DST On/Off (Daylight Savings Time) - Use the “ + , - ” buttons to turn
DST on or off. Press “ SET ” button to confirm.
Now you will select the calendar settings-
6. Select Year - Use the “ + , - ” buttons located on the back of the home
receiver to adjust year setting. Press “ SET ” button to confirm.
7. Select Month - Use the “ + , - ” buttons located on the back of the
home receiver to adjust month setting. Press “ SET ” button to confirm.
8. Select Day - Use the “ + , - ” buttons located on the back of the home
receiver to adjust day setting. Press “ SET ” button to confirm.
9. Select Fahrenheit/Centigrade Temperature Readings - Use the
+ , - “ buttons located on the back of the home receiver to toggle
between Fahrenheit or Centigrade readings. Press “ SET ” button
to confirm.
Mar 17, 2008 | Refrigerators
41 people viewed this question
Top home Audio Players & Recorders Experts
Lawrence Oravetz
Johnny Massengill
Johnny Massengill
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
