Is 172/82 high . I am 62 - Televison & Video
I have a winchester 22 cal pump rifle,SN 67106. What model is it and what is its value? It was purchaced inGreen Bay, Wisc. just before the end of WW 2.
Winchester Model 62 Pump Action Rifles The ultimate gallery gun
Several models of Winchester 62 pump action rifles. Top to bottom: 1906, 20-inch round barrel; 1890 octagonal barrel; prewar M62 with scope; postwar M62A.
Winchester Model 62 left side receiver. The huge "Winchester" rollmark may mean its a gallery gun.
No less than six generations of the Model 62 were made from 1932 until 1958. Three of these are pre-WWII while the other three are post-1945. The easiest way to tell postwar versions is that they have a 17-groove 8.75-inch foregrip while prewar versions have a 5.75-inch 10-groove grip. After 1940, the Model was modified with an improved hammer spring and dubbed the 62A, so if you see a 62A mark on your Winchester pump rifle, that is an easy way to tell that it was made after that year. The value of standard Model 62/62As start at about $300 for shooter grade guns and go as high as $1000.
Oct 27, 2016 | The Optics
Why does the oil gauge run high?
62 is not high oil pressure (my dully runs 80 psi)
if smokes after extended driving check pvc valve (when was last time you changed the oil?)
Aug 03, 2015 | 2004 Chevrolet Tahoe
How high should I hang the lamp over the table?
The bottom of the shade should be approximately 30-32 inches off the top of the playing surface. If you're hanging the lights before you locate your table the distance from the ground should be 60-62 inches high.
Jul 31, 2012 | Sport & Outdoor - Others
How much is 100x.62cents ?
Multiply 100 by .62 and get 62 cents.
If you mean 100 times 62 cents (the same as 100 times $.62), multiply 100 by 62 to get 6200 cents or $62.
May 25, 2011 | Office Equipment & Supplies
It makes a high pitched whine at about 62 mph
Vacume line off of transmission won't alow high gear and at that speed the tranny starts screaming for relief. Find the vucume line and make sure its good and connected at both ends
Nov 16, 2009 | 1991 Volvo 240
Vibration between 55 and 62 mph
Check wheel bearings on all four corners and check front ball joints and tie rod ends for play.
Mar 29, 2009 | 1998 Ford Windstar
High Temp Dishwasher
nope does not look like Hbart ser #
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
