Question about Lexmark X7170 All-In-One InkJet Printer
Paper want go in to print
My roller is rolling, but it's not pulling my paper in. keep getting a message saying - Lower exit tray. The tray is down, but it keep saying - lower exit tray
    Scholar:
  • 136 Answers
The reason why it keeps saying this is cuz you paper feed tire needs replacing. Now i am not sure based on the cost of this unit if it would be worth to have this repaired but, this is what is causing this error.
Posted on Jul 24, 2009
Printer is loaded with paper, but out of paper message appears. The message instructions are to add more paper and press continue to print. I've checked the paper rollers and blew air in to clean. ...
the roller rubber that is pulling the paper has a problem either it is worn out or not rotating you can have a visual inspection on the paper tray observe whether the rubber is rolling after you command a print..if not then you need to open the case of your printer and check for any brocken belts and gears that holds the rubber roller.
check also the switch that senses the paper feed at the tray it is a small switch that is triggered by the paper when you insert.
the message out of paper is cause by a time out of the paper to reach the printer head because of difficulty of feeding the paper the roller wont engage thats a out of paper message appear..good luck just post back if you have question
much appreciated if you cn click the 4 thumbs uo button for my effort this keeps me going!
Aug 23, 2010 | HP Deskjet 3845 InkJet Printer
When printing paper gets stuck. Not rolling thourh
LANIER COPIER PROBLEM SIMILAR TO RICOH COPIER PROBLEM AND IF THE PAPER GOT STUCK ,FIRST YOU MUST SEE AT WHICH
LEVEL/IS IT CRUMBLEB OR JUST MESHED THROUGH OR JUST UNABLE TO PASSED OUT FROM TRAY.
IF PASSED OUT FROM TRAY BUT STUCK AT DUPLEX AREA ,THAT MEANS YOUR FINGER AND MYLAR/RUBBER ROLLER MUST BENDED OR NO GRIP SO YOU HAVE TO REPLACED IT.
IF STUCK FROM THE TRAY, EITHER YOU DID NOT NOT " FAN" THE PAPER BEFORE USE AS NO AIR BETWEEN THE PAPAERSOR HAVE TO REPLACE THE PAD AND UPLIFT ROLLER RUBBER[1 PIECE ONLY PER TRAY]
IF STUCK AT FUSER AREA,JUST CHECK THE UPPER & LOWER ROLLER, THERE SHOULD BE THE ROLLERS NOT MEET TOGETHER. NEE MORE CLARIFICATION
Mar 31, 2010 | Lanier Office Equipment & Supplies
Error message says"out of paper" when paper tray is fully loaded
check and make sure that the paper is in near the rollers enough that it senses the paper and picks it up. try lightly pushing the paper down toward the rollers as it is suppose to pull one sheet through the feeder. hopefully, you didnt pull too hard on getting the 'jammed' paper out that it may have caused a misalignment in the feeder. try assisting the paper, that usually fixes it. hope this helps!
Aug 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Ruppled printed paper cannot exit output tray
you need do follow steps:
1) check fuser unit, the fuser hot roller is hot or not? if not the fuser heater fail.
2) check hot roller should spin with the pressure roller which is against hot roller, and check there is no gap between them, and also nothing pieces paper obstruct there, because if it losts pressure balance that jam should be occured there.
3) check the output roller after fuser unit(if there is), check them are spin or not, this roller kit use for pull the paper goes out the tray. if not spin means the roller drive belt or gear loosen.
3) check paper sensor that is micro swtch around pulling roller or output area and to clean it (could be a optical sensor).
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Samsung ML-2510 Laser Printer
Paper jam
take out all the paper from the loading tray, and press down on the inside of the tray 4 or 5 times, and put a sheet back in. There seems to be a physical irregularity with all 2300DL printers that causes this problem
Sep 19, 2008 | Konica Minolta magicolor 2300DL Laser...
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
Check printing on ML 1750
Your check paper might be too thick for the printer. It has been designed to handle paper 20-40lbs. If common paper prints fine, it means that the printer is not able to bring the check paper to the exit tray, where the fuser is located. The fuser is the part that heats and makes the toner print permanent. Try printing your checks through the manual tray.
Apr 30, 2007 | Samsung ML 1750 Laser Printer
I need help.
If your priter is showing a 241 paper jam and the paper stops in the paper tray or lower front, then you can replace the pick rollers to fix this problem. If the paper stops in the middle, then check to make sure the sensor flag in the middle left of the printer is clean and in place. If the jam is in the back of the printer then check the fuser rollers to make sure that they are rolling when the printer starts to print, check the exit sensors on the fuser, there are usually two flags, one on each side of the fuser. If there is no paper stuck in the printer, then make sure that all sensor flags are up and not stuck halfway down. Or check for dust in the sensors.
Apr 04, 2007 | Lexmark Optra T614 Laser Printer
Lexmark X7170 All-In-One InkJet Printer Logo
200 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
