Question about Coffee Makers & Espresso Machines
Just opened my jura c60, plugged it in. Light on coffee/froth button lit and working; no light on programming button. Pushing P does nothing.
  • 139 Answers
SOURCE: pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Posted on Jun 25, 2009
SOURCE: Jura Impressa E fails to dispense, then gives "open tap" message
I had the same problem, when I called their very helpful customer service, I was given these directions.
Take out the tray.
Inside the machine you can now see a flap hanging from the top.
Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
Wipe the filter with a paper towel.
Put the machine back together, and voila you got your coffee brewing again.
Posted on Jul 07, 2009
  • 3197 Answers
SOURCE: My Chamberlain Liftmaster Formula 1
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Posted on Jun 13, 2011
Geekman
  • 32281 Answers
SOURCE: Nespresson aireccino plus. Brand new out the box, plugged it in, added cold milk pressed the button, it worked for 5 seconds then the light started flashing and it stopped frothing. It also stopped he
Contact Amazon and tell them of the fault, ask for a warranty replacement or a refund.
Posted on Jan 25, 2012
SOURCE: coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Posted on May 27, 2012
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    https://www.youtube.com/watch?v=HlCu5m9isT4
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    https://www.youtube.com/watch?v=_jF_8rNUn4A
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    https://www.esperanza.ch/.../download_manual_jura_impressa_z5-gen2_...
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jan 31, 2016 | Coffee Makers & Espresso Machines
Leaking steam valve
Jura are a top brand and offer service and repair on their machines. Ask your local Jura dealer for a repair estimate.
Dec 20, 2013 | Jura Capresso Impressa E9 Espresso Machine...
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Jun 27, 2010 | Nespresso Aeroccino Automatic Milk Frother
My jura impressa z5 is having trouble foaming the milk...worked fine last season but we can't seem to get it foaming the same as it was before...suggestions??
The common cause is that the frothing connection is faulty. You can look at the Guide to clean the Jura frothing connection, or try this. Take some bicarb or vinegar, dissolve in 400ml luke warm water, select cappuccino maintenance under the options, or press the milk button. Run the complete mixture through then. Run about 600ml of plain water through the spout. Turn the sport from froth to milk and back every 10 seconds.
If this does not work, then there may be a need to decal the machine.
Jan 24, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
I have an Impressa Z5 and it won't **** milk up the tube as either part of the cappucino program or the stand alone milk program. I've checked and nothing in the nozzle is blocked and the plastic pipe...
There are three possible causes to milk not frothing: 1. The frothing tap is blocked: to unblock either use the cappuccino cleaner from Jura, or in 400ml of luke warm water dissolve a teaspoon of vinegar or 1/2 teaspoon of bicarb and run this liquid through the frother until completely finished (or run the cleaning program). The run about 600-800ml of water through the system. While passing the liquid through let the tap rest at froth, and milk setting for 5 seconds at a time. Repeat if necessary. To prevent this in future clean frother after 5 minute of none use. 2. The breathing nozzle is blocked, you can use the Jura Maintenance guide to see how to disassemble and clean and reassemble, but most Juras come with a spare, so replace it. 3. The machine needs to be descaled, since there is lime or scale in it.
Jan 15, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Coffee maker beeping
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
