I keep getting an error message on my fire stick that says: "FireStarter: Something went wrong, restarting HomeButtonObserver now.." Latest version & still the error.
Can I uninstall the application and still run Kodi without it?
Beni S-P
  • 1006 Answers
SOURCE: Installing and Using WD Passport Port. Hard Drive
Reapiring OS will fix your problem
Posted on Jan 27, 2008
ecmorgan69
  • 279 Answers
SOURCE: Failure to restart after installing sprint smartview
Use System Restore. Back it up to before you installed the offending hardware.
Posted on Dec 29, 2008
SOURCE: error message wrong cartridge
its not a true fix but I had the same issue. I turned off printer and slightly moved the paper thickness lever over a few inches. I turned it back on and the cartridge error was off. I do get a pop up from my printer program on the computer every time I initiate a print job asking to correct the lever, I click OK and it prints. I know its aRube Goldberg fix but I need this printer every day for work and for now it works.
Posted on Aug 11, 2009
techbuster
  • 5081 Answers
SOURCE: Keep getting application error message for YAHOO
a) Make sure you are the administrator and if not right-click on the installation program and click "Run as Administrator".
b) Use the Windows Installer Clean up Utility to uninstall the Yahoo messenger completely
Description of Windows Installer Clean up Utility: http://support.microsoft.com/kb/290301
Then install the Yahoo Messenger 10 from the link http://messenger.yahoo.com/win/
Posted on Dec 26, 2009
bronk50
  • 27725 Answers
SOURCE: The application failed to initialize
your disk drive might not be getting continuos power
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Nov 25, 2010
How do I reset my first generation Kindle Fire and where is the reset button
Restarting Kindle Fire may resolve intermittent issues like a frozen screen, battery issues or trouble downloading content to your Kindle Fire.
To restart your Kindle Fire, press and hold the power button for 40 seconds and then release. After the device has completely turned off, press the power button to restart your Kindle Fire.
If your Kindle Fire is still unresponsive, try charging your Kindle Fire before trying to restart the device again.
Make sure you have the latest software version available installed on your Kindle Fire. The latest version is available at www.amazon.com/kindlesoftwareupdates
Mar 01, 2015 | Tablets & eReaders
Hp dv7 laptop skype video message error
Seems the Skype community are having similar issues..
Try this:-
Please make sure you are using the latest version - currently 6.9.0.106. You can check your version in the menu "Help -> About". If you are running an older version please manually download and install the latest Skype version.
NB: The "Check for updates" features will not yet prompt for the 6.9 update.
If not check to see if they have posted anything newer here:-
http://community.skype.com/t5/Windows-desktop-client/Facebook-connection-issues/td-p/1962633
Dec 27, 2013 | HP Pavilion Computers & Internet
Hello my name is Amy and i recently had to do a complete system recover to my pc, Well when i went to reinstall my Kodak ESP.3 All-in-One Printer it loads the bojour and when it starts to install the Kodak...
Before you try re-installing it again, restart your computer. Sometimes installed programs require restart even if they don't force it on the user.
After restart try installing the software again, if it fails with the same error then your installer may be corrupt or not suitable for your OS. Go to the Kodak website and download the latest software and drivers for your printer. Here is the link. You will have to click on the right side on Downloads to select your OS and then search for ESP 5 will show up the results.
If you get the same error, check to see if you have the latest Service Pack installed (do a System Update for MAC). Update your computer and try again. By this time you have everything up to date and if it still won't work I'd say that there must be something corrupt into your OS.
Dec 05, 2010 | Kodak ESP 5 Printer
Ddraw.dll not found
Note: If you've already downloaded ddraw.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
  1. Restart your computer if you haven't yet.
    The ddraw.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the ddraw.dll not found error.
    Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
    Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
  3. Assuming the latest DirectX version from Microsoft doesn't fix the ddraw.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
    Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
  4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with ddraw.dll and a reinstall could do the trick.
  5. Restore the ddraw.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your ddraw.dll error, try extracting the ddraw.dll individually from the DirectX downloadable package.
  6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
GOOD LUCK AND PLS RATE THIS POST AS FIXYA!!!!!
Nov 16, 2010 | Yahoo Messenger
My Lexmark x502n printer won't print. I keep getting the message "Firestarter 4.0C:/VM/KILO/WORK@2" on the display. It prints one page of a fax again and again, then just stalls saying it's still...
You may need to update the Lexmark X502n firmware. Here's an article in the Lexmark website on Firestarter message; Firestarter 4.0C:/VM/KILO/WORK@2; Will not print. Just click on this link: http://bit.ly/9RCTXp. Follow the instructions carefully. Hope this helps.
Jun 09, 2010 | Lexmark X502N All-In-One Laser Printer
Firefox will not let me install adobe flash player .. I get error message after error message
Fire fox should have nothing to do with it. You could uninstall fire fox, install your flash player and then reinstall firefox. A couple of reasons for this problem could be, one, the flash player is from a dodgy site and fire fox is at odds with it, or the second is you have not got the latest version of fire fox. The only thing that should be at odds with the flash player, if there was something wrong is your operating system, not your web browser.
Jan 27, 2010 | Computers & Internet
I keep getting internet script error messages even after ive installed an updated version of adobe flash
use the later version of yahoo messenger then 7 and before the latest one
Dec 10, 2009 | Yahoo Messenger
Will not allow me to view pictures I just took
Try to recover what is left on the memory stick with TestDisk on a pc.
Note, download the windows version and not the dos/windows version, the
dos/windows version is for windows 3.11 and lower.
http://www.cgsecurity.org/wiki/TestDisk_Download
Try to fomat the card afterwards if this does'nt help at all try another card in
your camera, if the other card works replace your other card else get te camera autorized repairs man.
Succes.
Aug 28, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
I am told: "Could not load language, DLL, version information is incorrect. Error Code O" It seems something went wrong when I tried to load the latest protection, yesterday
Not sure what program is giving you this error but I would go to the programs web site and do a search in Support for "language.dll" to see if there are any known issues.
Jul 23, 2008 | Computers & Internet
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
