What is HC code or error - Washing Machines
What causes error code Hc?
This error code indicates that the cold and hot water inlet hoses are switched.
This code will appear at the end of the wash cycle to indicate that the cold and hot water inlet hoses are switched. If an error code does not appear, but you are experiencing poor wash performance, check to see if the inlet hoses are reversed.
May 12, 2015 | Washing Machines
Gree air conditioner error codes HC
I have also use GRE ac inverter but today my ac on running sundunly show (HC )Main screen
Plz information this system
HC maens what's problem
Aug 19, 2013 | Heating & Cooling
Kul dehumidifier error code as unplug and plug back in still has the error code.
"For the above error codes, Power the unit off, and then unplug the unit for 15 minutes. Plug in and power on. If the issue persists, please contact customer service."
https://edgestar.zendesk.com/hc/en-us/articles/201000315-My-dehumidifier-is-displaying-an-error-code-What-does-it-mean-
Apr 28, 2013 | KUL 65 Pint Dehumidifier
HC error code....have not touched the hoses since it was installed...?
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched.
If the hoses are not switched it could indicate a problem with the Electronic Control Board.
You can try to rest the washer by unplugging or flipping the breaker to the washer for 2-5 min.
Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa
Aug 05, 2011 | Maytag Bravos MVWB700V Top Load Washer
Error 0701: USB Over Current on HC/Port
Error 0701: USB Over Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00HCurrent On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
Sep 28, 2010 | Lenovo 3000 C200 Notebook
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
