Como quitar la base de una pantalla plana aoc 32'' L32W761???
pazman
  • 81 Answers
SOURCE: pantalla se ve como infrarojo
possible que tienes que deconnectar todos los cables y reconnectar los patras, Y tambien la coriente de la tele.
Posted on Apr 09, 2008
adracamas
  • 344 Answers
SOURCE: hola , tengo una pantalla de 32 element. tengo 2
Si sólo lo he tenido durante dos días debe tomarlo de nuevo al lugar donde se ha comprado ella y pedirle al comercio para trabajar uno.
Perdona mi como yo he tenido que usar un programa traductor para hablar con usted. No sé español.
Posted on Aug 05, 2010
  • 2336 Answers
SOURCE: LA PANTALLA DE MI TELEVISOR
Estas partes para servicio no son producidas debido a su alto costo. Si puedes encontrar una usada, esa seria la unica solucion para reparar tu LCD.
Yo tengo una pantalla usada, hazme saber si te interesa comprarla.
Posted on Nov 10, 2010
bbl242003
  • 1637 Answers
SOURCE: ¿como ver la pantalla donde
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
  • 11800 Answers
SOURCE: mi televisor comenso con
A wavy line and a partial image are a sign that at least the convergence board has failed. The fact that now the entire image has failed means that the video board has failed also. This signals a very severe failure in the tv, most likely it all started with the failure of the power source.
Open the tv and first check that the capacitors on the power source are intact - follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
Then check that the voltages that should be delivered by the power source are there - measure them. Then repair the convergence board with this kit
http://www.tvrepairkits.com/xcart/product.php?productid=21850&cat=2749&page=1
and then test the rest of the tv with the repaired board in place to determine what else has failed : check the video final board and the tubes - measure the voltages on the tubes and the final video transistors.
Posted on Aug 12, 2011
Se apago mi tv led electrosonic y no prende
Fallo de la placa principal fuente de alimentaci?n del regulador. Compruebe y sustituya los componentes da?ados / s en su principal regulador de potencia [SMPS] Circuito secci?n. P?ngase en contacto con cualquier t?cnico de servicio. Si desea obtener algunos detalles; comprobar el sitio vinculado aqu?. Navegue por la web con paciencia. Tire hacia arriba de las entradas m?s antiguas.
Ser? mejor para reemplazar el tablero regulador de la fuente de alimentaci?n como base la tarjeta en lugar de hacer "cirug?a" a ella; que por lo general har? que la p?rdida de dinero y tiempo. A pesar de que usted puede hacer las cosas bien, que costar? alrededor de una cantidad igual al coste de una nueva junta directiva; incluyendo el costo de (partes + cargo por servicio de repuesto) M?s que decir, la mayor parte de las piezas de repuesto ser? dif?cil obtener de libre mercado de repuestos electr?nicos. Esto es cierto para la mayor?a de los tableros de alimentaci?n del televisor de pantalla plana de suministro; independientemente de su marca y tama?o de pantalla.
Jan 29, 2014 | Insignia IS 20" TV040919 TV
Como desarmar
primero desmonta el motor de la base. luego en el motor hay tres tornillos en la parte donde entra el cable de alimentacion, quitalos. luego en el cabezal movil quitas un tornillo allen 4mm, en el vastago donde se acoplan los accesorios debes quitar una chabeta y el pin de seguridad y luego halas toda la pieza y abras quitado la tapadera de los engranajes. espero te sirva de algo la respuesta
Sep 21, 2013 | Hamilton Beach 63221 Stand Mixer
Quiero vender mi registradora casio PCR-T2000A, necesito resetearla a "0" como lo hago?
La forma mas rapida para restablecer esa maquina es quitar el enchufe de la pared y saquar las baterias, dejalo alli durante cinco minutos, reemplaza las baterias primero, seguido por el enchufe en la pared.
Al girar la llave a Reg prenda la maquina. Una fila de ceros aparecean en la pantalla. Ahora puedes configurar la maquina desde el principio, incluyendo hora, y fecha codigos de impuestos.
Jul 08, 2011 | Casio Parts Cash Register PC Desktop
Quero saber como dismontar uma memoria ram
desconecta la notebook de la corriente electrica pon la notebook con la pantalla hacia abajo y localiza la ranura de memoria vas a necesitar un desarmada para quitar la tapa una vez que quites la tapa veras la memoria sugeta por 2 laminas separalas con cuidado para liberarla
para inserta una memoria nueva la colocas en angulo presionas con cuidado hasta que las laminas la sugeten de nuevo
Mar 28, 2011 | Dell Inspiron E1505 Notebook
Como aser para recetar chip de la T430
1. entra el menu de CONFIG de la impresora. Para hacer esto:
1. enchufa de la impresora.
2. con la impresora enchufada lejos, aprieta y sujeta tanto el boton Selecto como el Regreso abotonan.
3. al mantener ambos estos botones presionaron, enchufan la impresora atras en.
4. cuando la pantalla de impresora dice que MENU de CONFIG o Principal Valor de Cnt, suelte los botones.
2. aprieta el bot?n de Menu de flecha hacia la derecha hasta que vea Repone Maint Cnt (o Repuso Maint a Conde) como una elecci?n.
3. aprieta el boton Selecto una vez. Debe ver Repone Maint Cnt en la l?nea primera y = Repuso en la segunda l?nea de la pantalla de impresora.
4. prensa Selecciona otra vez. Esto repondra al conde de mantenimiento para poner a cero.
5. salir el men? de CONFIG, aprieta el Regreso hasta que regrese en el principal menu.
6. aprieta la izquierda o boton de Menu de flecha de derecha hasta que vea la Salida Config Menu como una eleccion.
7. prensa Selecciona. Esto debe guardar que poniendo y vuelve la impresora al modo Listo. La NOTA: Si usted se pierde durante cualquiera de estos pasos, apriete el boton del Regreso para volver al principal menu. Hacer esto no cambiara ningun ajustes. Alternativamente, puede enchufar lejos la impresora por unos pocos segundos y comenzar otra vez.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Lexmark T430 Laser Printer
ERROR SCANNER 22 EN IMPRESORA HP LASERJET ML1120 MFP
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
Dec 02, 2010 | HP LaserJet M1120 MFP All-In-One Printer
COMO PUEDO QUITAR EL MODO DEMOSTRACION DE UN SONY BRAVIA 32BX3000
Entras al menú .... ajustes.... inicio automático. Ahí empieza una configuración inicial del TV y encontraras una seleccion de Modo entre Tienda y domestico. Seleccionas domestio y listo.
Un saludo...
Nov 02, 2010 | Sony Televison & Video
COMO CAMBIO UNA CADENA DE TIEMPO Y DONDE ENCUETRO LOS DIAGRAMAS
tengo un mazda mpv le cambie los baleros no le podia quitar el sensor y quise quitar la polea de la del motor y se movi el tiempo como puedo ponelo vien o conseguir un diagrama
Oct 20, 2010 | Mercury Cougar Cars & Trucks
Como cambiar la lampara
si ves la tv por el frente tienes que quitar el grill the las vocinas, es muy facil, agarra el grill y hala hacia afuera, solo tiene unos clips,luego mira hacia la parte central de la tv y veras unas letras negras y tiene la informacion de la lampara.hay 3 tornillos que tienes que quitar(desarmador philips) luego veras la lampara nesecitas un desarmador plano y son otros 3 tornillos.aflojalos y hala la lampara hacia afuera.luego installa la lampara nueva haciendo el proceso alreves. hacegurate de poner el covertor de la lampara antes de encender el televisor. y si te pregunta si cambiaste la lampara preciona enter(cuando enciende la tv en letras en la pantalla.. buena suerte .
hdtvman.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
927 people viewed this question
Top Televison & Video Experts
