Question about The Office Equipment & Supplies
Prints fading, don't print properly, if printing more copies. What could be the issue?
smunteanu
  • 43 Answers
SOURCE: Printer only prints partial page
The carousel central axel has been twisted.
Posted on Mar 18, 2008
SOURCE: tlp 2844 printing issues
try powering off the printer, pressing the green button while powering back up then when u see it blink let go of the green button
Posted on Jun 25, 2008
leroyal
  • 2120 Answers
SOURCE: faded on left side of prints
The only thing left is the HIGH VOLTAGE POWER SUPPLY.
Have you removed and cleaned the LASER UNIT?
Posted on Feb 06, 2009
c_robertson
  • 123 Answers
SOURCE: prints photos with yellow horizontal stripes.Hv downloaded HP printing diagnostic utility and no errors were reported. If just using scanner to copy photos, prints fine but copying photos in library p
go into the printer and do a test print. start>printer & faxes>right click on the printer in question>properties>printer preference button> test print ... try the printer's own test print. This is usually caused by a poor print head, low ink, poor cartridge or the need for calibration. Look in the maintenance tab in the printer properties for head cleaner, jet cleaner etc. This also happens with refill ink cartridges.
Posted on Apr 29, 2009
CompuFirm
  • 89 Answers
SOURCE: Print fades out from right side of page
Check out this website it will assist you with all the known printing problems out there,
This could be anything from a transfer roller to a defective ink cartridge. However the above link is for troubleshooting print quality problems with your printer
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=239135&prodTypeId=18972&prodSeriesId=239135&objectID=bpl12234
Posted on May 27, 2009
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ā€Ž12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
Faded prints samsung clx3185 fw
Got one clx 3185fn printing black only. even press color copy button.
Cartridges are new. Please advise.
Thanks
mearmi@hotmail.com
Oct 26, 2012 | Samsung CLX3185 AllInOne Laser Printer
Faded print on right hand side
Hi Tracy,
If faded prints happen even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printer.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, faded prints are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 07, 2011 | Epson Aculaser C1100 Printer
Prints half pager
* Does the same issue persist while making a copy from the unit?
* Does the unit prints self test page properly? Steps are given below:
  1. Make sure the printer is loaded with unused white paper.
  2. Press and hold Cancel on the printer control panel.
  3. Press Start Color Copy .
  4. Release both buttons. The self-test page prints.
Apr 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
When scanning a picture, the picture comes out faded even if the picture is clear and crisp.
Most scanners allow you to chose what resolution that you want to scan the photo at and you may have selected too low a resolution, for example for the web. If you want the highest resolution scan you need to select the TIF option if its there. If not, select the highest number available.
When you say its "faded", do you mean when it prints out or when it shows on your computer screen? If its when it prints, obviously it could be a printer ink issue or maybe your printer is set to "fast print", which gives poor resolution and may look how you explain.
Sep 12, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Light or Faded Areas in Solid Color Prints
If the issue is occuring in the same place on all prints, try the imaging drum (can't remember if this printer even uses one) or the transfer belt/roller (not sure which it uses). If you phone Dell support, they should run you through troubleshooting and send you either of those parts free of charge if you are under warranty. If not, buy them anyways; they don't degrade over time (if kept in the dark) and can be saved for when the currently installed one runs out if you don't need it to fix this issue.
Nov 27, 2008 | Dell 3010cn Laser Printer
Old Polaroid photos
Having photographic quality copy prints made will give you far longer life than the original Polaroid. Polaroid colour dyes will shift colours and eventually fade dramatically. New photographic (and some ink jet) prints will last generations without noticeable fading.
Feb 24, 2008 | Photography
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
23 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
