My sentient 4-camera system shuts down after 30mins and sounds high pitched continuous alarm ? What is wrong. ?
  • 337 Answers
SOURCE: No picture only a high pitch sound
Yes,it can be repaired,sometimes for no reason components fail and they need to be replaced,if you are familiar with tv service you can check the horizontal output transistor,it might have gone bad(shorted out)and is all is going to take to get the set back running,sometimes the output trasformer damages the transistor and both have to be replaced,first just change the transistor and if it blows up again then replace the transformer,if you are not too familiar with servicing a tv be safe and call for assistance from a servicer,if you take the set to them it should be expensive.Let Us know how it goes or if you need more information.
Posted on Nov 08, 2006
SOURCE: Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Posted on Mar 02, 2009
  • 585 Answers
SOURCE: hd tv makes a hjgh pitched sound whats wrong
Hi, the high pitched sound is coming from the coils or transformers on the power supply.
you can isolate the noise by removing the back and with the set on press gently with a plastic handle/item on each coil till you stop the noise. , you will probably have to replace the coil or the whole power supply, but sometimes you can tilt it over or secure it with silicone and it will stop rimging.
please click a thumbs up it this helps solve your problem
Posted on Aug 19, 2009
  • 43501 Answers
SOURCE: constant high pitched noise emitting from furnace
This is probably a dry bearing in the vent motor. Those motors run at high RPM's and can make a deafening high pitched squeal if they become dry and need oiling.
Some of the motors have oil cups on them for dripping oil into and others;s are much more difficult as you need to guess where the bearing is and try to drip oil down into them or run the oil to them.
Any light weight small motor oil ike a sewr machine oil will work.
Many hardwares have small oil bottles with extending spouts made just for oiling motors for just a couple of bucks...
The other thing that can cause this is if the blower wheel is coming loose and has moved to the side and is hitting the side of the blower housing. Take the bottom cover off and check for play or movement side to side in the blower wheel. Spinning it with the power off by hand may give you a clue as you will hear it scraping the side of the housing.
Posted on Dec 29, 2009
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Posted on Jan 27, 2010
High pitch alarm sound when vehicle on or off
try disconnecting the battery and reconnecting
Dec 20, 2013 | Audi Cars & Trucks
High pitched squeel from the hard drive and then shuts down.
restart the computer HOLD the keys CTRL +F11 OR F12 depend of your mark, model, and go restore to the factory default, and fix it.
Passs the antivirus+antimalware very IMPORTANT!
God bless you
Jul 20, 2013 | Acer Computers & Internet
Castelgarden TCR 102 continuous buzzer
This sounds like the bag full indicator, there will be a switch and lever somewhere on the back that has become permenently engaged.
Mar 04, 2012 | Garden
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
High-pitched alarm-like sound coming from GE frig - TBX22PRYCRAA
Very common problem is the evap fan located in the freezer section is the cause. Sorry but this is controlled by the main board on the back and only way to fix the problem is with a new board. Sorry about the news but it is the problem.
May 31, 2010 | GE PFS22SISSS Stainless Steel French Door...
Cannot delete events from Sentient N663HH 4 camera DVR system.
go to hard drive setup
you will need to overwrite over it.
go to overwrite on your set up and select yesto enable to overwrite harddrive when capacity is full
May 20, 2010 | Cameras
Electrolux dual range has a high pitch sound. Shut breaker down to stop the noise but it continued. Any suggestions?
its electricall disconnected nad your still getting a high pitched sound???? that would only leave your gas connection as the culprit
Mar 22, 2008 | Kitchen Ranges
Sylvania Television shut down suddenly with a high pitch sound at the back
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
Figure on replacing the flyback transformer.
Hope ya fix it!
Jan 28, 2008 | Proton MM2701VT 27" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
