Question about Health & Beauty
Replacement Combs for HC900 - Health & Beauty
Larry.Combs.Jr@gmail.com
Go directly to Gmail to straighten this out.
Apr 16, 2014 | Computers & Internet
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
I can install the HC900 to 3600 meters above sea level?
Altitude should have no effect on the machine...
Just make sure to keep it clean so you get good airflow/cooling...
heatman101
May 09, 2011 | Mitsubishi HC900 Multimedia Projector
How to get remington hkvac 2000 replacement combs?
replacement combs can be found on amazon for good prices (from proven sellers.. take a look on reviews). take a look:Amazon com remington combs. I hope this was helpful. cheers
Dec 13, 2010 | Remington Health & Beauty
Not sure,but is the screen supposed to spin or not? 2 of the 3 blade screens spin,is that normal? Should they all spin,or should none of them spin? From what I can tell,all actual blades are spinning...
The combs (screens) should not spin. They need to be stationary so the hair can most effectively poke into the slots to be cut
If yours are spinng, either they are not put in correctly of they are damaged and need to be replaced. To check for damage, take them out and try to turn the blades inside the combs with your fingers. The blades should turn freely inside the combs. If they stick, they are damaged and need replaced.
If you require replacements for model 4401LC, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/specials/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
Sep 26, 2010 | Norelco Micro 4401 LC Electric Shaver
How do I change out the air filter for the 2200 model? Not sure where to open it up in order to check the air filter and if needed change it out. Thank you.
After you pull out the filter case. There is a tab on the bottom and on the top that holds the ends in undo these.lift out the combs and the filter. Open the new filter and hook it onto the tabs of the filter case and close the ends back up. Get one of the combs in all the cracks of the new filter then slide the next comb in right next to the one that is installed and slide it down to the furthest slot where the combs go. and do this for the rest of the combs until they are all inserted. once they are all in replace the filter case into the cavity be sure to line the slots up on the case and the cabinet and put the door back on.
Jan 03, 2010 | Aprilaire 2200 Air Purifier
Need a part number for the color wheel. thank you model # HC900
Here is the complete list of components part No used in your projector download and save it for your future use it's in pdf format
www.panasonic.com/business/provideo/support/includes/pdf/parts-services/exploded-view/AK-HC900.pdf
Jun 16, 2009 | Mitsubishi HC900 Multimedia Projector
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
