Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Carburetor run only on chock as soon as you take chock off it will stop
  • 132 Answers
There is an air fuel ratio screw loosen that off and it will run off choke
Posted on Jul 24, 2009
Starts right up and runs...dies when chocke is opened past half way
the carburetor needs to be cleaned or a new needle and seat installed. engines will start but may only run on choke, are starving for fuel. this means that the carburetor has a problem. usually a good cleaning and maybe a needle and seat will cure this problem.
Mar 12, 2016 | Garden
Just put a new carburetor on my sears blower an in only run on half chock
The fuel air ratio is incorrect. If it has an adjustment screw on the carburetor, turn it slightly right or left, don't worry because you will "hear" the engine differentiate..
Nov 07, 2015 | Garden
Honda pressure washer won't stay on with chock pushed in stays on chock pulled out see video
It has a plugged jet in carburetor remove carburetor and clean all the jets that should help. If not it may need valves adjusted.
Jun 28, 2014 | Garden
Runs for 10 minutes and stops
When running is the idle smooth or up and down?
Is the chock operating, or adjusted after the motor gets warm?
Is the carburetor needle adjusted after the engine idles to warm as it should be to be set correctly.
Are you blowing snow when it dies or at idle?
Feb 01, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
My engine (briggs 6.5) runs and then stops. I found a crack in the intake tube. replaced it. Ran great, now doing the same thing again. If I keep \r\npumping the primer button, it will run. Soon as...
The main jet of the carburetor is likely blocked by a piece of debris. You are going to need to remove the carburetor and clean it thoroughly. If it is one that has the carburetor mounted on the fuel tank, replace the diaphram while you are at it.
I hope this was helpful.
Sep 04, 2011 | Briggs & Stratton Briggs Stratton...
For mtd 3hp 2cycle motor only stays running when pushing prime repeatedly on full chock 5 sec
This is usually a symptom of blocked or partially obstructed metering passages in the carburetor. Carburetor should be removed and metering passages cleaned to restore fuel flow through the carburetor.
Feb 12, 2011 | Tecumseh Snowblower Snow Blower Starter...
Poulan pro 42cc starts when choked,take off choke runs almost 1 minute and dies.chock and restart same thing. will not stay running even when throttled.
Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. If no help, remove the carburetor, disassemble and clean the interior with spray carburetor cleaner. Check the condition of the diaphragm in the lower chamber--it should be flexible with no holes or cracks. Also check the small needle valve that the diaphragm controls. Check the crankcase impulse passage behind the carburetor for gasket failure or other damage. This passage pulse-pumps additional fuel into the carburetor as it runs. Hope this helps!
Jan 14, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carburetor diagram
Honda Rider Club membership provides a generic service manual for members. For a small fee, you can join and get access to the manual for your model according to info at the site. http://hrca.honda.com/
Apr 26, 2010 | 2003 Honda CRF 230 F
Excel powerwasher with B/S motor. Will start and
Is your air filter dirty? If so replace it. If it is still doing the same thing try this:
Turn off the fuel valve, or drain the gas tank, then place a rag under the bowl to catch the gas that will run out (the bowl is under the carburetor). Loosen the "nut" that holds the bowl on, and after the gas has stopped draining remove the nut and bowl. Blow out with compressed air, if available. Put the bowl back on and try to start it. If it still will not run off choke, the carburetor probably needs a good soaking or to be replaced.
Jan 25, 2010 | Briggs & Stratton Pressure Washer...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
242 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
