Question about The Office Equipment & Supplies
SABC Stores uses an application designed by MICT. The application allows customers to order LCD TV Sets of their specified sizes given by the area of the LCD TV Screen.
3.1.1 List five rules for creating variables. (5) 3.1.2 Define variables you would use to code this application. (5) 3.1.3 Draw a flow chart for the logic to calculate the area of the LCD Monitor. (5) 3.1.4 Draw a hierarchy chart for the logic to calculate the area of the LCD Monitor.
    Master:
  • The Master
  • 923 Answers
Are you looking for someone to do your work for you? Aren't most digital TV's set up as a 16:9 aspect ratio? Does that tell you anything about what the height would be, for every chosen width? However, the standard way of describing the size of any TV (especially wide screen TV's) is to measure it as a DIAGONAL size. In the case of any TV, if you apply the Pythagorean Theorem, then simply SQUARE the width (multiply that dimension times itself), and separately, SQUARE the height, and add those two SQUARED values together, then find the SQUARE ROOT of those two combined values, and you will have the exact diagonal measurement! "In the case of a right triangle (any triangle have one angle of 90 degrees), the square of the hypotenuse is equal to the sum of the squares of the other two sides."
Posted on Apr 24, 2017
What size screws/bolts do I need on the back of my TV in order to mount it on my floor stand mount?
To know more, you have to download the repair manual to this set. Its disassemble section will have all the details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Nov 13, 2014 | JVC LT-46P510 46 in. LCD TV
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Lug nut issues
Your factory custom wheels are designed to use a specific lug nut, most of these lugnuts today include a built in washer that contacts the wheel surface. Your maintenance of re-torqueing the lugnuts after 100 miles following wheel removal is exceptional, and textbook...(some wheel manufacturers recommend this after 50 miles:) I am a long time wheel person through many years of performance wheel applications. My guess would be that a previous owner had installed custom wheels, and removed them at time of selling your Santa Fe...they mistakenly left the aftermarket lug nuts on your car...and these lug nuts do not contact your wheel where they should be to remain tightened...Don't buy new lug nuts unless you can test this possibility first...All salvage yards would have inventory of factory wheels and lugnuts...Also shop on line...confirm the size of your wheel studs...ie 12 mm rht..."right hand thread" and search for someone selling factory wheels...many auto parts stores will confirm your wheel stud thread size any offer replacement sets too. Hope this helps.
Jan 17, 2014 | Hyundai Cars & Trucks
FUJI XEROX Document Centre C400 can't set custom paper size
I found that I needed to be logged in as the Administrator for Win 7/64 before I could edit the custom paper size in the advanced printer settings for my P205b.
The printer driver has a stupid feature where you have to specify custom sizes privately to the printer driver before you can then choose that size in your application; you can't just enter a custom size in your application.
You also have to specify if that paper is to show up at 1:1 or some scaled value.
Because the driver didn't have A6 in its private list of paper sizes, I couldn't print in A6 at 1:1 because selecting A6 in the application produces a message saying that you can't print A6 at that scale factor!!!!!
Jun 16, 2012 | Office Equipment & Supplies
What are the tv remote codes?
these are the codes designed for programming the specified television sets
Sep 24, 2011 | Olevia LT42HVi 42 in. LCD Television
My mom is looking for a base for her 19" Trueteck tv. We have not been able to find any place that carries them. Could you please let me know where in the Syracuse NY area I could get one or even a...
Tries websites like Amazon.com,Ebay.com tries to find and buy it used most likely.Because the tv brand name TruTech LCD tvs are in very limited market for as in the LCD tvs for in sell,because it was specially design and sell in Target stores only.That the way,Target tries to a for little nit in the LCD tvs industries.This tv brands are carry by Target stores only,so u can tries buy used one from them or can find out how to order one from there supplier.
Jun 28, 2011 | TruTech PLV16190 Television
I just bought my tv last week, and it seems like the color scheme is out of whack. People's lips and ears are much more red or rosy than normal, and sometimes it looks like you can see the color going in...
H you haven't specified what type of tv it is but given it is last week you purchased, it can be assumed to be LCD/Plasma. A setup procedure I used to do on the old CRT tv 's when setting the customer controls were as follows.
1) set tv to locally transmittted programme material (eg News -NOT ADVERTS - They are always too bright
Sep 22, 2010 | Hisense LHD3204US 32 in. LCD HDTV
2004 KIA OPTIMA WON'T START AFTER SPARK PLUGS WERE CHANGES
HI. There are several areas of concern here. I will list them below. Check all areas stated in the list for faults.
Possible cuases:
1. Incorrect firing order set. On the 2.0, 2.4 and 2.7 engines. These engines are equipped with a distributor-less ignition system. This system incorporates a coil pack assembly, along with wire sets. In order for the assembly to fire correctly, the order of the wires must be set to the proper sequence. if not, the engine will not turn over, or start correctly. Make sure your firing order is correct, and make sure you have not placed a particular wire set into the wrong cylinder. I will post a picture of the correct firing order for your engine, below this list, shortly.
2. Incorrect spark plug gapping procedure. If the new spark plugs were gapped incorrectly, this will not allow for proper spark, thus, preventing optimal combustion, due to lack of fire. Check the spark plug gap using a wire gap gauge, and adjust if necessary. The gap should be 0.039-0.043 in. (1.0-1.1mm)
3. Failed coil pack assembly. This will be the worst case scenario. The coil pack supplies the necessary current that fuels each plug. The current is transferred, via wire sets.This will be the culprit if all the above areas are proven to be operational, and in good shape.
4. Failed wire sets. Replace the wire sets if faults are found at the connector at the ignition coil pack, or at the plug boot.
NOTE*
In order to provide the correct firing order for your engine, i will need the engine size and liter information, if possible. Please post this information, asap. Thanks..
Mar 24, 2010 | 2004 Kia Optima
How can I connect an ATL850 8.5 in. LCD TV to a cable box?
You have a ATSC Digital tuner in your set which accepts over the AIR digital transmission. Your set does not have the ATSC QAM tuner to receive digital cable transmission. Those size sets are usually designed for outdoor use with an antenna and for camping ect.....Outside of that, go ahead and connect it and see what happens...Do auto program.
Jun 07, 2009 | Lasonic ATL850 8.5 in. LCD TV
Can I get the asswer for the below questions
A book shop maintains the inventory of books that are being sold at the shop. The list has details like author, title, price, publisher and stock position. Whenever a customer wants a book, the sales person inputs the title and author and the system searches the list and displays a suitable message if it is not available. If it is available, the system displays the book details and requests for the number of copies required. If the copies are available, the total cost of the copies requested is displayed, otherwise the message ‘copies not in stock’ is displayed.
Design a system using a class called BOOKS with suitable member functions and constructors. Use new operator in constructors to allocate required memory space.
Nov 16, 2008 | Computers & Internet
130 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
