Question about Indesit Dryers
Hi Black and orange wires have come off the back of my indesit DCI 85 condenser dryer can you tell me where they connect to ?
  • 69 Answers
SOURCE: indesit is60v dryer
Shaz, di you ever find where the 2 wires go? i have the same problem, they came off whilst i was changing the belt.
Posted on Aug 09, 2008
SOURCE: indesit washer
if you mean the wires that go to the back of the drum from left to right= green circle=brown wire pushon tellow/green(earth) square =2 lite blues yellow circle=dark blue if this isnt what you needed please respecify and ill do my best to answer ,ian if you add to this post it will inform me for a faster reply
Posted on Nov 19, 2008
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
SOURCE: Indesit IS70c condenser dryer
Posted on Jun 29, 2010
  • 1344 Answers
SOURCE: indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Posted on May 11, 2012
My indesit condenser tumble dryerwont start
try door interlock......................cheers
Oct 07, 2016 | Indesit Dryers
Water not going into condenser drawer leaking underneath indesit IDC 85
have you cleaned the condensing unit out lately? they are usually located somewhere at the bottom behind a panel. they need washing out every month or so.
Apr 06, 2014 | Dryers
How to replace the motor on indesit idc75uk tumble dryer
Black Carbon is Not Good! This could be related to the Brushes on the motor and unless you are good at repairing a motor; I would advise getting a replacement. Write down the Make, Mod. and other details from the Motor label and look on line for a low cost replacement. To open the Dryer, just unscrew the back panel and look for the motor housing. In some cases, you may have to remove the Drum, pulley and/or drive belt. Be careful because the Metal Is Sharp and it can Cut your hands or Arms. The motor when exposed can be removed from the dryer housing by removing the screws/bolts and attached wire connections. Remember the order in witch you took it apart because that is way you put it back together. Remember the exact attachment of the electric wires prior to pulling them off of the motor (Red and Black/or White wires). These wires Must be reattached the exact way they were affixed at the factory. When done, replace the back panel and your done. I do hope you DISCONNECTED the Power Plug "FIRST"...Dah?
Dec 18, 2013 | Indesit Dryers
AC condenser motor 3 wires, black,orange,brown. Which is L1, L2 and capacitor ????
The black wire is usually the L1 line connection. The brown wire is usually the capacitor wire, and that leaves the orange wire for the other line connection - either L2 or Common depending on the voltage involved.
Aug 14, 2013 | Emerson Fan Motor & Blade - 1/6 HP
Replaced the thermostat and high limit regulator on my amana comercial dryer lea60aw but forgot to tag wires, starting from the thermostat on the blower, i'm not sure where the wires go to, i have
if i were there i could tell you.just think about it .the wires have to make a path all the way through the should have a wiring diagram in the control panel that will help you trace the path.hope this helps.
Dec 04, 2017 | Amana Dryers
Not sure which way round to replace thermostats on indesit g75c dryer? Does it matter?
HI ste richards...
The wires can be connected to either terminal of the thermostat
Please take time to rate me
Sep 19, 2011 | Indesit Dryers
I have an Indesit ISL70 and we seem to have developed a problem. Three red lights are flashing (water, filter, heat exchanger, all of which are ok) and the door won't open. Any advice?
Note:- The front NTC connects on the top edge of the circuit board - plug with two orange wires. The element and rear NTC are connected on the right hand side of the circuit board - this plug has 5 wires Blue, Orange, Brown, Red and Black.
1) The front NTC measures approx 500k ohms.
2) The rear NTC measures approx 500K ohms [red and black wires on the plug]
3) The resistance between Orange and Blue Wires is Approx 46 Ohms [This is one half of the element]
4) The resistance between Orange and Brown wires is Approx 46 Ohms [This is the other half of the element]
5) The resistance between the Blue and Brown Wires is approx 92 Ohms [This both parts of the element]
My machine has 2 devices above the element, one is an NTC the other is the safety cut-out. The safety cut-out is connected in the orange wire to the element common connection.
The resistance of the NTC's varies with temperature - so you may not get the figure I have quoted. The resistance reduces as the NTC warms up; if you remove the NTC connect it to an Ohm meter and warm the flat metal side with your finger you'll see the resistance go down - the drop wont be dramatic [after all your finger is not that hot] and is easier to see on a digital meter.
Measurements taken with the plugs disconnected on a digital meter... and don't forget folks MAINS PLUG OUT FIRST!!!!
Important.... there are some different versions of these dryers, so different readings may be obtained.
Dec 22, 2010 | Indesit IS70C Electric Dryer
Orange wire
look in the wire schematics that came with the dryer or look them up online. They should tell you what that wire is for.
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Forgot the manual to wire carrier fan coil - took care of the thermostat -but need to wire fan coil
Carrier wires are as follow Red black green whiteyellow. R common Black ground Y cool O or orange Reverse valve G fan W heat. The white on the Air handler depending on your electric backup heat has two wires together connected to white. Orange connects to orange on the condenser. Unless you have terminal board the everything is marked. Ruty
Jun 06, 2009 | Carrier Heating & Cooling
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Dryers Logo
26 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
