Question about Hardware & Accessories
Hi the black and orange wires have come off the back of the timer can you tell me where they connect to ?
SOURCE: CAN ANYONE HELP IM TRYING
if you go on google enter clarion ab213r wiring diagram
and it should tell you what every wire is.
also enter your vehicles info and look up the wiring diagram for that also
it should be easy from there
Posted on Mar 18, 2010
SOURCE: GE digital timer. Instructions say to: 1)
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Posted on Sep 26, 2010
SOURCE: installing a GE digital wall
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
When tester lights up, that is Neutral
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Posted on Sep 30, 2010
SOURCE: I am replacing an old intermatic model EJ341
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
Posted on Oct 04, 2010
SOURCE: For an intermatic EJ341 spring wound timer, there
Switch has 2 wire > one of these wires is Hot and it connects to Timer black wire > the other wire goes to Load and connects to Timer red wire.
If you get these two wires reversed, timer will not run, so switch them. You know timer is running when dial on front of timer rotates with passing time. You can test for Hot wire by taking out switch, separate wires, turn on power, test each wire to bare ground, tester lights up with Hot wire.
Timer white wire goes Neutral. This wire is necessary to run clock inside timer. Locate Neutral wire inside box >> it is usually two or more white wires twisted together and pushed to back of box. If you do not have a Neutral wire, connect Timer white wire to bare ground wire ... until you can hire electrician to run additional wire to box.
Posted on Oct 05, 2010
I have a junction box with a 3 way switch that operates hall lights, and a 2 way switch that operates outdoor lights. I want to replace the 2 way with the Woods timer (59018). I tried following...
Remove timer, and reconnect both switches as they were before starting.
Notice if there is a wire that connects to both switches... this will be the Hot wire.
Then notice that the 2-way switch has two wires.
One wire will be Hot > and this wire connects to timer Black wire.
And the other wire goes to Load (light) > and this wire connects to timer red wire.
The timer green wire connects to bare ground wires.
This leaves the timer White wire > you can connect timer White wire with the other ground wires.... > or look in the back of switch box to notice a group of white wires covered with wire nut > connect timer White wire to these other white wires.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#59018
Gene
h
Oct 28, 2013 | Coleman Cable Woods 59018 InWall 7Day...
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
I have a 3 gang box: a is for hall light switch
Timer is not identified. Battery-operate timers wire differently than timers that require neutral wire.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
For 4-wire battery-operated Intermatic EJ500, ST01C, and Ei600, Ei400 wiring:
http://waterheatertimer.org/ST01C-program.html#ST01C
For 4-wire Intermatic Ei200 series, KM-series, Ei500 that require neutral wire
http://waterheatertimer.org/Programmable.html#wire
Add a comment with model number for more specific information
Jun 19, 2011 | RTO Intermatic Digital 7 Day Wall Switch...
Hi, I am trying to install a Leviton time switch. in the wall box I have a single black, a single white and a copper wire. Here's how I plan to wire it up: wall switch black (hot) ...
The white wire is used to power electronics inside timer:
Single pole switch has two insulated wires.
Remove both insulated wires from switch.
Timer black connects to one of the insulated switch wires, or to Hot wire from breaker
Timer red connects to the other insulated switch wire, or to Load wire going to fan, light, motor.
Timer white connects to Neutral wire from breaker box. Neutrals are white wires that are twisted together and pushed to back of box.
If box does not have Neutral wires, then connect timer white wire to bare ground wire.
Timer green connects to bare ground.
Turn power on, and check if timer is working. If timer is not working, then reverse timer black and timer red wires.
This wiring information has been tested and is accurate.
If timer does not function correctly with correct wiring, then move timer to another location to see if timer is defective, if timer does not work on specific Load, then noise or interference on line can be suspect. Also check ratings for timer and compare with Load ratings.
If you have countdown timer connected to whole house motor/fan, then horsepower rating is important consideration. If timer is rated 1/6 HP and whole house fan is 1/2 HP, then timer will not work.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Apr 14, 2011 | Leviton Timer Switch 5-10-15-30 Minutes, 4...
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
I am trying to install utilitech 7 day in-wall timer. Their are 3 switches in box controlling different fixtures. The old switch had black connected and a black looped to the next switch. How do I connect...
1) Wires in box:
Black looped to to next switch is Black hot wire
Other Black goes to fixture
2) Connect timer wires
Black timer wire goes to Black hot
Red (or Blue) timer wire goes to fixture
White wire connects to white neutral wires (usually connected together with wire nut and pushed to back of box)
Green goes to bare ground wire
Sep 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I bought a Utilitech 7 day digital in wall timer, the wall switch only has a black (hot) and white (neutral) wire going to it. The new timer has black, white, red and green (ground). What do I connect the...
HI .. if the switch has only a black and white wire attached, and there are no other wires in the wall box, then you cannot use this timer switch. You need to return it and get a timer that does not use a neutral connection. The wires you have are a switch leg from the light and there is a white wire but it is not a neutral.
If there are other wires in that wall box , tell me and we can chat more about how to remedy this .
Please Vote !!
May 25, 2010 | Hardware & Accessories
I lost my Leviton 6230M 30 mins timer installation sheet.
Switch has 2 black wires. One black is hot wire. One black is wire going to fan. Turn off power. Remove wires from switch and separate. Turn power back on. Using ordinary tester, test each black wire to bare copper ground wire. Only one of the black wires will test hot. The other black wire goes to fan.
Timer black wire connects to black hot
Timer blue wire connects to black wire going to fan
Timer white wire connects to white neutral (in absence of white neutral, connect Timer white wire to bare ground)
Timer green connects to bare ground wire
May 24, 2010 | Leviton 1000W / 20A 1HP-120V - 6230M-I -...
Orange wire
look in the wire schematics that came with the dryer or look them up online. They should tell you what that wire is for.
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
I have a Kenmore refri/freezer model 106.7687460. with the icemaker removed the unit will not operate. I need a wiring diagram or which wires needs to be connected at icemaker connection.
Good day,
the defrosting control is a part of the ice maker. If you don't care about appearances, you can wire around it.
First, you have to buy a 8 hour 20 minute Whirlpool defrost timer.
Any sharp appliance parts house counter guy will know what you need. It comes with one of the clock wires un-attached.
As well, you will need 4 insulated 1/4" female spade connectors.
Buy spares to be safe.
Cut the cord from the old ice maker at the ice maker.
There will be 5 main wires and a green ground wire.
Strip about 1" of the green wire's insulation.
There will be 5 wires left. red-orange-black-pink-brown.
Tape the brown wire back it will not be used.
strip back approx. 1/4" of the remaining wires. crimp a spade connector to each of the 4 remaining wires.
The terminals will look like this.... | | | | on the timer.
Notice the space between the first terminal and the second, compared to the rest.
We will call the terminals on the timer from left to right, 1,2,3,and 4 even though the timer will say differently.
Connect the loose wire on the timer to terminal 4.
Plug the red to #1, Orange to #2, black to #3, and pink to #4.
Plug into machine, and run to test. If O.K. then........
Using high quality electrical tape, tape everything exposed well.
Mount the timer to the wall using one of the left over holes from removing ice maker.
Drill a tiny hole, close to that area, and using a good self tapping screw, attach the green grounding wire. Detail your work as necessary.
It's ugly, but it works. Actually, I install the timer inside the case after gutting the works. If you want to try that, DO NOT cut the cord, as explained at the beginning.
Note: Some supply houses may still sell the adapter, already made up. You can check. In either case, you must have a timer in the circuit for defrosting.
Dec 03, 2009 | Kenmore Refrigerators
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
