Question about Sanyo Office Equipment & Supplies
Anytime i am watching my sanyo t.v. slim type the channel flips to a.v. mode and subsequently an 3 alphabets appear on the screen.CLR,
In this CLR mode everything including the remote refuses to function unless i restart the T.V. what's the problem please?
snakehead
  • 1074 Answers
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Posted on Jun 04, 2007
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Posted on May 25, 2008
SOURCE: Controller Freak Out
on the base of the joystick there is a rubber ring that sort of gets stuck. mine did that and i removed that ring to fix the problem.
Posted on Feb 15, 2009
bernardlunda
  • 318 Answers
SOURCE: Change input channel
FIRSTLY consider buying a remote @ $44.95 only
get connected to
www.twenga.co.uk/dis-audio-video.home-cinema.remote-control-228-554k
to change a channel hold both channel buttons at once, your tv will give you menu and later go in programming channel
or
hold one channel button, sweep through all channels at the end you will enter AV
Posted on Apr 25, 2009
bshldn
  • 736 Answers
SOURCE: I was watching tv and the screen went blank. It
You would have to try an INIT and see if it causes the tv to be operational again. It is something that you have to be walked through step by step by step and can erase the memory of the tv if done improperly. Call Sharp tomorrow morning at 9AM CST and someone can walk you through one. Call 800-237-5277 or if you have an aquos advantage model call 87-332-7867
Posted on May 15, 2010
Says all channels lock , and all scanner mode locked.
see the user manual here...http://www.cabelas.com/assets/product_files/pdf/636073_uniden_bc125at_owners_manual.pdf
it says: Unlock all Channels in Banks Currently Enabled for Scan 1. Press Hold to stop scanning. 2. Press and hold L/O until Confirm Unlock All Channels? appears in the display. 3. Press Pgm/E to unlock all or. Clr to cancel.
Dec 03, 2015 | Uniden Bc125at Handheld 500 Ch. Special...
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
How do i delete channels from sanyo tv that i do not want to watch?
On my Sanyo DP50740 you, go to Menu, select Channel Setting, select Channel Scan memory, then just go to the channel in the list that has a check mark by it and push enter to remove the check mark and it will no longer show up when you flip through the channels but you can still access it by entering the number manually.
Nov 20, 2010 | Sanyo Televison & Video
Please find my motorola security code
To enter the secret menu mode: flip open phone and quickly enter: #073887* then enter your Security Code (default is 000000). It has menu items Web Sessions, Browser Reset, User Activation, AKEY, Extended NAM, Vcode, Data Rates, SPC Overwrite, System ID, SID/NID Pair, Test Mode, and Get It Now Config. Note: to get out of test mode (white background and blue text), press CLR then left soft key quickly. User Activation
To enter the secret menu mode: flip open phone and quickly enter: 74663#[CLR][CLR]. You will see the "User Activation" menu and have two items listed: NAM 1 and NAM 2.
Enter Operator Codes
TODO: 3/30/2006 - Find if this is available on the VZW Phone.
Jul 15, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
Tv in video mode
sanyo model: AVM-21 MB
problem: during tv mode the reception will loss and back
in turn to blue color then back to channel frequency!
at video the picture is okay but ther is no audio!
can you please suggest me how to solve this problem
can you send this to my email add.
albertdlc_12yahoo.com thank you and more power!
Jul 21, 2008 | Sanyo AVM-3259S TV
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
"Line In" mode (on both TV & VCR) -- (Please help) "Get (them) Back to "Normal"!"
it sounds like you need to get a universal remote that has an av setting on it usuall this is 0 or an av button this shoud toggle between these modes sorry couldnt be any more help
Oct 31, 2007 | Televison & Video
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Oct 31, 2007 | Hitachi VTFX631A VCR
TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Aug 20, 2006 | Sanyo DS27800 27" TV
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
