Question about Ovens
The fan is turning on by itself without using the oven, what to do to stop it? thank you.
2 Suggested Answers
SOURCE: oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Posted on Jan 09, 2009
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Kitchenaid KEMS378sss fan noise
Does it keep heating food? You do not run it without the fan very long and maybe it will shut off or down when it senses the fan stopped and might stop cooking. You want to isolate it is the fan and not the magnatron (cooking device). It is pretty new for that but always a posibility.
Do you have a straight vent fan that you can turn on without cooking? try that and see what you get. If it does the same, I think you have a defective fan.
e
Nov 19, 2011 | KitchenAid Architect Series KEMC308KSS...
The main oven fan in Hotpoint BD32B is sticking (tries to rotate but goes slow and stops). I need to either re-lubricate the existing fan or replace it. How do I remove the fan?
Remove the cover at the rear of the oven compartment, then holding the fan blade with one hand, undo the nut holding the fan on, it is a left hand thread, so turn the nut clockwise as though you were tightening it.
To remove the motor itself you will have to undo 3 screws securing the fan motor from inside the oven compartment, then remove the outer rear cover of oven to remove the motor.
May 10, 2011 | Ovens
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
Why does my Jenn Air convection oven make such a LOUD clattery/ticking noise whenever I use it? I think it must be the fan...can you help?
If you can get at the fan blades without taking anything apart, try to turn the fan blade by using a small screwdriver or even a small wooden skewer. Listen to see if the blades are making contact with either fan cover or the back of the oven or the edges of the convection opening.
Once you determine which blade(s) are making contact, use a sharpie marker to mark those blades you need to correct. That way if the blades are hitting the fan cover, you'll know which ones need to be bent back into shape once the cover is removed.
With the oven turned off, you should be able to remove the circulating fan cover and correctly bend the fan blades back into shape and stop the noise.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Ovens
Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
Fan stopped working
If it is heating without the fan working, then there is probably something wrong with the fan.
If there is no heat as well as the fan not working, then check that the timer is set to manual and not on auto.
To access the fan and heater, remove the rear panel inside the oven, spin the fan by hand,it should be completely free,
If it is not, then it needs replacing.
Thanks
Jan 02, 2009 | Belling XOU252 Electric Single Oven
Oven switches 'itself' off without the timer
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
