Question about American Standard 2771.018WC.222 Cadet 5' x 36" Whirlpool, Linen
The tub/water stopper...how do you take that off to unclog hair in the drain?
The overflow drain / stopper lever has 2 screws holding it in place, place a rag over the drain and remove the 2 screws. then remove the drain assembly, it should slide right out. You can now clean the assembly, you may still need a piece of wire to fish the hair out.
Posted on Jul 24, 2009
How do I take the drain plug off so I can clean it out?
If the drain is one like this
https://www.plumbingsupply.com/images/foot-actuated-tub-closure.jpg
You can remove it by unscrewing the cap anticlockwise. You may need vise-grips. Pad the jaws with masking tape.
If it is one like this
http://www.mustknowhow.com/wp-content/uploads/2010/04/drain.jpg
You must remove the center screw and strainer. In extreme cases you may need to remove and replace the drain flange with a special wrench
http://images.meredith.com/diy/images/2009/02/p_SCP_167_08.jpg
In some locations there is no center screw to the strainer, which is all one piece with the flange. These cannot usually be removed without access to the big nut on the underside of the tub
More info here
http://www.familyhandyman.com/plumbing/drain-repair/unclog-a-bathtub-drain-without-chemicals/view-all
May 08, 2015 | Home
Water is draining from hot tub after its filled & dont know why
Hi Mary,sounds like your drain stopper may not be closing tight.Try removing the stopper by turning it counter clockwise,then jam a small rag in the drain as tight as you can to stop the water and fill the tub.If it still leaks then the drain plug where the stopper goes may have to be re-sealed or one of the jets may have a leak.If the tub is over a ceiling do not keep re-filling the tub you will cause major water damage to the rooms below.
Jan 05, 2014 | Leisure Time Filter Clean 1 Quart - 12...
I accidentally clogged my bathtub.
Liquid plumber or a good quality drain opener should disolve the foam things. Pour about a pint in and let it set for about 30 minutes, then flip the stopper up to seal off the drain. Run about 1/2 the tub full of hot water, open drain, and plunge rapidly with a plunger. This should fix your problem....(plumber 20 years)
Jun 11, 2012 | Home
I can't remove the tub drain to unclog it. tried vinegar and baking soda but need to remove to unclog. How to do, can't see a set screw. the drain is a pull up and turn to open/close. HELP! i'm showering...
I will do my best to explain this ---- the little button on top of the drain cap unscrews counter-clockwise,, I have found it best to push down the drain cap with one one hand ( very hard down )and with your other hand turn the button counter-clockwise. if it still will not budge then you might need to get a pair of channel locks and a pair of pliers and get it that way. now as soon as you get the button off -- the center spindle unscrews using a large flatblade screwdriver,, unscrew it and it will all come off. if you have anymore troubles - please feel free to write back and I will do my best to walk you through any steps.
c...
Feb 03, 2011 | Moen Tub Drain Assembly, Lift-N-Drain -...
I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
May 21, 2010 | Plumbing
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
How do you get hair out of a drain that is in a Jacuzzi. Can I unscrew the drain stopper or can I remove the chrome plate further up the tub?
unscrew what ever is covering the hole where the water drains out,.... use a pair of needle nose pliers or an old coat hanger with a little hook pre-bent in it (don't get it stuck in there) and pull out the hair,....it's that easy! good luck, cracklin joe
Jan 04, 2010 | Jacuzzi Rotary PVC Drain Kit DA34-815
Slow water drain from Royal whirlpool tub. How to
under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
Jul 29, 2009 | Home
My bathtub drain is American Standard circa 1927. The tub stopper is actuated by turning a knob connected to a linkage connected to a rod, connected to a yoke which threads onto a sleeved pipe which...
your close to figuring it out,
I would guess you have a hair clog in the trap. they have inexpensive plastic rods (like a long zip tie) with serrated edges on it to capture the hair. Home Depot or Lowe's or Menards will have these
Jun 28, 2009 | Plumbing
Bathroom tub drain clogged
If you have a popup/ plunger type drain stopper controlled by a lever at the overflow, then, yes, it would be a great idea to remove that. They commonly add to drain problems.
Remove the two screws at the overflow plate (the one with the lever for stopping the water). Be careful that the gasket between the tub and overfow does not fall out when you fully remove the screws. Pull out the stopper assembly. You may have to jiggle it somewhat. Clear your drain some more and run a little water in it. Then replace the stopper assembly, making sure to keep the overflow drain lined up as you screw the plate back in.
You may consider replacing a lever stopper with a "twist and twirl" type.
If you do not have a lever assembly then you may have to use a small hand held snake to clear out the drain
Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
American Standard 2771.018WC.222 Cadet 5' x 36" Whirlpool, Linen Logo
468 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
