How to drain water and there are 2 hose one stick out from the a/c or i just unplug the one sticking out and drain the water?
nenalex2002
  • 134 Answers
SOURCE: 2 gig ram stick
Absolutely, 2 Gigs stick of RAM exist. Unfortunately your motherboard's maximum memory supported is 2GB. This site specifies very clearly 1 gig stick max per slot:
http://www.crucial.com/store/listparts.aspx?model=P5VD2-MX+SE
A.J.
Posted on Jan 28, 2008
SOURCE: Water runs out of the bottom of the unit
Check your plastic water orifice. It is in the hose fitting connected to the outlet tube of the water solenoid. It should be a blue one. Mine was completely eaten through, allowing full water flow, and thus overflowing the distribution tray. I replaced mine yesterday and no more water drips. May as well reflace the filter on the inlet tube of the solenoid at the same time. I used a piece of very stiff, but thin, wire formed into a small hook to remove both old parts. Replacements are readily available from multiple sources on line.
Posted on Feb 06, 2009
whytfang
  • 170 Answers
SOURCE: ariston dishwasher sticks on drain
hi you may have something in the sump there's a screen on the right side ofthe spray arm with 2 screws remove them and take screen off use yourfingers to probe the cavity be careful it could be glass. If there is something in here it will make a grinding noise and stay in drain cycle forever.
If it does not correct the problem
!.You may have an electric pump . and it could be a check valve at the pump and hose assembly...where the check valve is...see below . so it could be a bad pump but I doubt it.
GE dishwashers will have a sumpentrance screen ( #4 ) that should beremoved and checked for any gookus, see 1 or 2 screws on the cover top, which isbehind the lower spray arm. Almost all ( some newer GE dishwashers have a separatedrain pump and motor - but for our purpose, we will talk about the mostcommon GE dishwashers ) GE dishwashers have a drainsolenoid ( #1 ) that can fail and stopthe draining. If the solenoid cannot pull in the silver plunger, the drain portwill not open to allow the motor and pump assembly to drain the water out. Thesolenoid can be ohmedwith an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GEdishwashers have a selfclean filter ( #3 ) inside at the back.The draining water must pass through a plunger in the self clean filter body.This can get clogged up, or the plunger may twist and distort and not allow thedraining water to get past. The filter can be removed from the inside and theplunger will twist out of the self cleaning body for testing/checking. Next obstaclefor the draining water in the backflush valve ( #2 ). This valve can twistor distort and block the water flow as well. The drain port will need to beaccessed to check this flapper valve, the drain port will untwist from the selfclean filter body. All hoses in-between the items mentioned above and the drainhose itself all the way to the house plumbing should be checked forrestrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled waterfalls down the back of the tub and into the filter area. The water comes throughthe filter and back into the tub. During the wash and rinse periods all ( wehope! ) the water will pass through the filter. The soil will settle into thecollection chamber and is held there. When the dishwasher goes into the pump outmode the water in the sump is pumped through the collection chamber. This closesthe piston valve to the inside of the tub. The pump flushes the collectionchamber of all the food soil and pumps it down the drain. A check valve islocated in the drain line port. This valve allows the water to flow in the draindirection only and prevents the water from coming back into the tub. The drainline check valve must close in the back flow direction or the piston valve inthe collection chamber may not reopen into the tub after the pump out iscomplete. Water should "fall" through the filter and go back into thetub....the heavier food particles go down into the chamber and are collected.
Hereis a link for you to check out...I have all this info in my data basebut since it is in PDF format it does not translate well to thisformat...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and good day...please rate my effort......thanks....The Fang.
Posted on Apr 07, 2009
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
  • 662 Answers
SOURCE: mACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Tip
What is wrong when your washer keep filling all the time
Gene
on Jul 30, 2011 | Washing Machines
Water won't shut off at specific load capacity
Good luck, i hope this helps,
Gene
Aug 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How to fix a Kenmore 90 Series when the water keeps running?
Good luck, i hope this will help you to fix your washer,
Gene
Aug 09, 2011 | Kenmore 22422 Top Load Washer
Model # 110.26832692 does not stop filling up with water when the load selector size is set will overflow if I don't stop it!
Good luck, i hope this helps to figure out what is wrong with your washer,
Gene
Aug 05, 2011 | Kenmore Washing Machines
My washer water never shuts off water runs all the time had to turn off the valve to get washer from filling up
I hope this has helped you,
Gene
Aug 04, 2011 | Roper Washing Machines
Washer keeps filling with water never shuts off overflows
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking.
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement.
Gene
Aug 04, 2011 | Kenmore 26422 Top Load Washer
Does not stop filling up with water
Gene
Aug 01, 2011 | Kenmore Washing Machines
Water continues to run. Will not stop when machine is in the wash cycle.
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
My washer will not drain
Hello there:
I would check the drain pump for a clog. Remove the front panel of the washer, the pump is at the front bottom right side, with 2 hoses attached. Now either get the water out of the tub with a shop vac, or pinch off the hose connecting the tub to the drain pump. Take the top hose off, and stick your finger down the hole and feel for anything. also you can stick a screw driver down the pump and see if the impeller moves freely...
Read more: http://forum.appliancepartspros.com/washer-repair/8486-ge-washer-will-not-drain-spin.html#ixzz10rBUaUUw
Sep 28, 2010 | GE Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
