Question about Car Audio & Video
I need the treble and bass knobs for an FISHER RS-1060. Anyone help?
  • 38 Answers
SOURCE: MX5021- Remote pod station w/volume, bass and treble control
Posted on Dec 04, 2007
SOURCE: Altec Lansing 4.1 ADA880
if you are a technically skilled person
simply clean all the IC(chip) leads, by using a blower or using a painting small brush
the dust come in contact with the other pins that make this problem
Posted on Jan 24, 2008
  • 8197 Answers
SOURCE: finding treble and bass adjustments on my stereo
Here is a manual for the radio. If you go to page 14 it will tell you how to set the EQ.
Good Luck Please Rate FixYa!
Posted on Dec 19, 2008
  • 1114 Answers
SOURCE: How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Posted on Jul 01, 2009
SOURCE: I need a bass knob for my crunch amp
i need an bass knob for an planet audio rxd2400
Posted on Nov 11, 2009
Need to know how to adjust bass, treble, fade, etc. on Alpine model CDA-7862
Press the MODE knob to choose between bass, treble, balance, or fade.
Turn the MODE knob to change each setting as it is displayed.
Mar 15, 2011 | Car Audio & Video
Line 6 Spider III 15W- My Bass and Drive knobs arnt working... my mid and treble seems to be fine plus all my channels and effects but just those two knobs...and its buggin the **** out of me.... any...
resolder the three legs of the pots back down to the pcb. usually the treble feeds the bass, then from bass to mid then to ground. so if treble and mid are working its hard to imagine why the bass wouldnt be working. i would try to resolder, as you might have cold solder joints. keep it unplugged, pull off the knobs, open it up, remove the pcb screws and pull/flip out the pcb and resolder all of the pots.
May 25, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
Can not turn the bass and treble up or down on my alpine CDA-9827
ok i cant see your entire question but to adjust bass and treble on an alpine, you see the knob (the one which u use to turn volume up and down), push it in (itll click) then a screen/textt will come up and say bass or an option once it says bass, turn the knob up or down, then press in again and it will say treble or fader or something else, once again, adjust it and keep pressing in the knob until u reach the volume again. does it work? is this what u wanted?
Apr 11, 2009 | Alpine CDA-9827 CD Player
Radio bass,treble control knob does not work and feels loose
you have two choices. either replace the radio. or open the radio up and tighten the 11mm set nut behind the face to restore the operation of the loose knob.
Apr 10, 2009 | 2003 Chevrolet Monte Carlo
Sony radio cdxgt210
Use the main control knob. The one that turns your volume up and down. If you press it in it should go through bass, treble, fade, balance, and sub. Then use that same knob to adjust it by turning it left or right.
Jan 20, 2009 | Car Audio & Video
Finding how to set the treble and bass
Under the silver volume knob is a thin silver bar. Push it and the menu will pop up on the screen. Continue to push this bar to scroll through the different options. It controls bass, treble, balance, fade, sub volume etc. Good luck, hope this helped.
Dec 19, 2008 | Alpine CDA-9833 CD Player
Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Aug 10, 2007 | Alpine CDM-7861 CD Player
Nakamichi cd-35z
There is adjustment for bass, mid and treble. Access this by pressing the button to the right of the volume knob. I leave mine set at +1/2, -3, +2 . I also set LOUD on which is done by holding the same button down. With these settings everything sounds pretty spot on, occasionally need to adjust the bass up/down and treble dependant upon the CD.
Mar 09, 2007 | Nakamichi CD-35z CD Changer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
