Question about Luxor Televison & Video
How do I reset pin no for luxor tv - Luxor Televison & Video
Luxor TV won't connect to preset tv channel apps. It keeps saying it needs to be connected to an aerial but it shouldn't because these apps should work through the wifi. Help please?
Did you get any advice elsewhere. My Luxor tv is doing the same thing. I don't have aerial input. Hence why I bought a smart tv. Netflix and YouTube are fine.
May 26, 2017 | Luxor Televison & Video
How can i reset my tv to factory settings the tv is Luxor 140001b/01
There are two methods to reset. Hard reset and factory reset. To make it a hard reset unplug the set from the AC mains wall socket and reinsert after an hour or so. To make it a factory reset you have to enter it's service mode option. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 18, 2017 | Luxor Televison & Video
How to reset luxor smart tv to factory settings
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Can you fit soundbar to luxor tele s
You should be able to, sound bars are normally connected via a cable with a small inner round pin (approx 3mm) and a square outer with a ridge on 1 side. The tv should have the connector labled for sound in on the tv. Hope this helps.
Jun 26, 2016 | Luxor Televison & Video
My luxor TV has froze on the options as I was trying to retune TV how can I fix the problem.
Do a reset to this TV & check. If it do not help you, contact any service technician or the authorized service center. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 20, 2014 | Luxor Televison & Video
NEED HELP BAD. Luxor TV (Asda) keeps resetting my settings when turned off and on!
Main system control memory IC fault. Contact any service technician to replace it.
Jul 27, 2014 | Luxor 19822 COB
Menu controls
sometimes pressing either both channel or both volume buttons willl get you in the setting
Jun 18, 2012 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Luxor Televison & Video Experts
Sp Gupta
sureshd2008
rugby prop
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
