Question about Sony Audio Players & Recorders
How can i solve a fault with sony STR-DE595 which displays protect?
    Top Expert:
  • Sony Master
  • 39,323 Answers
Protect mode is entered as a result of overload or component failure. Cold solder joints may be a factor as well.
Posted on Apr 20, 2017
  • 85 Answers
SOURCE: playing ipod on sony str-de595 receiver
You need a 3.5mm mini jack coupler lead with phono plugs on end plug one end into your headphone output on ipod and phonos into your amp lead must be stereo
Posted on Jan 09, 2009
mjjdesigns
  • 98 Answers
SOURCE: PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Posted on Mar 25, 2009
shadtremonky
  • 353 Answers
SOURCE: why doese the display window flash
it is over heating
Posted on Jun 25, 2009
  • 5 Answers
SOURCE: i need help
first check for any loose speaker wire in the back as this will cause the unit to go into protect mode if the bare speaker wire is touching, if thats not the case then there is a problem with the unit internaly and would be hard to tell whats wrong with it without looking at it.
Posted on Dec 12, 2009
  • 336 Answers
SOURCE: why can't I play a turntable through my
Turntables have a very low output level. Receivers with a phono input have a op-amp to boost the signal level.
What you can do: Check the turn table it may have a line level switch under the rubber mat, otherwise you can get a phono amp ($20-$40) to boost the signal. and input it to any unused input on the receiver.
Posted on Jan 10, 2010
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
Aug 21, 2011 | Sony STR-DE595 Receiver
I have a Sony STR-DE595 receiver that I would like to connect to powered speakers. How do I do this?
One way would be to follow the directions supplied with the unidentified powered speakers. Lacking details we can't really provide a good answer.
Jul 21, 2011 | Sony STR-DE595 Receiver
The SONY STR DE595 goes into "protect" mode upon turning it on.I recut all speaker wires & vacuumed the receiver ...unplugged,differenet outlets...etc.Any advice?
The protect thing is to do with an overload. It's more than likely that something in the main amp section has failed (perhaps a transistor on the big heat sink). The cause often speaker wiring touching together. You should look carefully at the this section for damage or burning. If you have a ohm meter you can test the transistors. If you place the probes on the terminals of each transistor and you get a responce like you had touch the probes together, you have located the source of the overload.
Sep 04, 2010 | Sony STR-DE595 5-Channel Amplifier
Why can't I play a turntable through my "Sony str-de595
Jan 10, 2010 | Sony STR-DE595 Receiver
Question about Sony STR-DE595
NO! It uses the same amps for a and b channels. and you could short it out if its wirer improperly.
Dec 17, 2009 | Sony STR-DE595 Receiver
Playing ipod on sony str-de595 receiver
Dec 22, 2008 | Sony STR-DE595 5-Channel Amplifier
Sony SRT-DE595
go into the speaker setup menu and turn subwoofer to YES
Dec 08, 2008 | Sony STR-DE595 Receiver
Sony STR-DE698 7.1
in Sony receivers Protect display shows problem / fault in Amplifier output area. Qualified technician can repair the damage.
Regards,
Sep 04, 2008 | Sony STR-DE698 Receiver
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
