Question about Refrigerators
Element 40 how many boards are in it,i took the back off and only seen 1 does that power everything. thx chris
2 Suggested Answers
  • 10865 Answers
SOURCE: drivers side seat heater element is bad
Hi Chris. I recommend that you forgo Ebay and order what you need directly from GMpartsdirect.com. You can get the seat kit and the back kit sepatately and each is in the 75 dollar price point. The "element" is a mesh that you install under the upholstry. Not a difficult job. The fact that the dealership wants 500 is why many folks call it a stealership
Posted on Dec 14, 2009
How do I repair nonfunctioning backlight?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 03, 2015 | Element Electronics Element 40" LED 1080P...
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check shopjimmy.com
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
Not getting the amount of hot water I used to get
Remove power from WH Remove heating element covers and, insullation you will see two screws and, a red button (reset) for each element; push the button for each element to reset them; put everything back repower and, test. If the problem is still there: Remove power, test element screws with a meter set for resistance; if no continuity drain WH and, replace element(s)
Apr 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My kenmore stove wont turn off no matter what, we have tried unplugging it and everything but it just wont.
Hello-  The circuit on the control board that switches power to the elements has fused. This tends to happen during the self-clean cycle. The board needs to be replaced to fix this problem. Have seen some of these catch fire, so don't plug it back in until new part is in. Make sure to inspect power cord connections at back of unit.  Replacing control is fairly easy, but repairing any damaged wires should be left to a pro...  Let me know if this info helps- have more if needed- Thanks- Ed
Mar 18, 2010 | Kenmore Kitchen Ranges
Drivers side seat heater element is bad
Dec 14, 2009 | 2005 GMC Sierra
40"smasung hd tv won't turn on anymore
Mine was doing the same thing. Opened it up and had 2 bad capacitors on the power supply board. If you take off the back it is the board in the center. The bad caps are seen by a slight bulge on their end. The ends sticking up have a cross shape imprinted on them. They should be totally flat. The bad ones will be swollen slightly. The bad caps on mine were 2200 uF 10 volt. Note the orientation and replace. They are very cheap. Just use the high temp ones. 105C. Took me less than an hour to replace and be back up and running.
Apr 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
UNIT WILL NOT TURN ON
I am having the same problem with mine. It's plugged in and everything looks as it should inside, but i can't get the thing to turn on.
Mar 12, 2008 | Maytag M7DH45B2A Dehumidifier
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
