Question about Fujitsu Cell Phones
How to calibrate Fujitsu 6670 - Fujitsu Cell Phones
What can be done to fix my fi-6670?
You may need to lubricate the moving parts. I had a printer that was playing up like this and the bars that the print head moved on needed a tissue with a small quantity of machine oil to be rubbed on the bar to allow the print head to move freely. If all the scanners are the same age the lubrication they had may have worn off.
Apr 29, 2014 | Fujitsu Fi 6670 - Document Scanner -...
Fujitu FI 6670 service manual
Fujitsu has documentation for all of their products on their website.
Here is a list of all the scanner docs:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/docs.html
For the FI-6670 they link to 3 different documents:
Datasheet [587KB]
Getting Started Guide [1.39MB]
Operator's Guide [12.7MB]
Jan 31, 2014 | Fujitsu fi Office Equipment & Supplies
Fi-6670
Here is the operation guide:
http://www.fujitsu.com/downloads/COMP/fcpa/scanners/fi-6x70_ops-guide.pdf
Dec 17, 2013 | Fujitsu Fi 6670 - Document Scanner -...
Fujitsu Fi-6670. I have a little (microscopic) piece of paper stuck under the lower screen, so when scanning it appears a blu line over the whole page. How can i get it out? Thanks
Hello Alex,
You need to open the scanner and de-assemble some parts to remove the piece of paper which involves technical expertise. I would recommend to contact a Fujitsu scanner technician or call your nearest service center for assistance.
Thanks & regards,
ScanCare
Aug 28, 2013 | Fujitsu Fi-6240 Flatbed Scanner
What's wrong if i get error e9
E-9 error in Fujitsu fi-6670/fi-6770 is the Image Memory Alarm which implicates scanner memory malfunction.Turn off and turn on the scanner, does the same symptom still occurs? If yes, then you may have to replace the DIMM located at the memory slots on the CGA board. If the issue still persists after replacement of DIMM, then you may have to replace the Control PCA. I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 17, 2013 | Fujitsu fi-6770 Flatbed Scanner
Error e9 on fi 6770 means what?
Thanks & regards,
ScanCare
Nokia 6670 not converting form phone memory to memory card
reset your phone..*#7370# then enter locked code..i hope it will help
Jun 06, 2010 | Nokia 6670 Cellular Phone
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Not boot
my nokia 6670 doesn't boot gives message while power on "phone start-up failed " thnx 4 help
Sep 07, 2008 | Nokia 6670 Handheld
Nokia 6670 repairing
infected by commwarrior
Mar 26, 2008 | Nokia 6670 Cellular Phone
Cell Phones Logo
Top Fujitsu Cell Phones Experts
gary_wil45
gary_wil45
Steve Dave
Steve Dave
Are you a Fujitsu Cell Phone Expert? Answer questions, earn points and help others
