Question about Murray Garden
I just got a Murray Spindle Housing, and Splin Shaft. How to put together ?
    Visited the website for 30 consecutive days.
  • Murray Master
  • 1,028 Answers
Mc Givers Workshop will help with that
Posted on Jan 17, 2018
3 Suggested Answers
  • 2176 Answers
SOURCE: Compound Mitre Saw Motor turning, spindle isnt.
I have went to 3 different sites and cannot find the model number listed on them, I did look at a Ryobi saw and they indicate it is an assembly. but before I did that I would try and removing the gear from the spindle. It is possible that when it spun it put a burr in the parts and you would have to use a little extra effort to remove them I would suggest going to a repair shop and having them press them apart and see what you canfind that way. Sorry I couldn't find more for you
Posted on Aug 21, 2009
  • 543 Answers
SOURCE: tips hints or tricks and detailed instructions for
no its goes on the shaft that comes out of trans,,put the opening on the clip facing up,for some reason its seems to go on alot easier with the clip up,,,,wiggle it on and make sure its straight then push really hard and get it to seat al the way on,if its not all the way it will pop off while driving,then youll have to get a tow,so make sure its seated all the way
Posted on Oct 19, 2009
Noma snowblower transmission is backwards, put in forward it goes backwards and so on
Dear Richard,
Your direction with the gears appears to be 180 degrees out. You may also consider flipping the entire shaft assembly. You. Knowing this assembly is put together correctly.
At this you tube link you will find information to watch for your Norma. The side bar with a catolgue has your answers.
Here is a forum and a blog that may help when the order is corrected
Small Engines Lawn Mowers etc Noma Murray Snowblower question
Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
Dec 09, 2014 | Garden
How do I fix a loose blade.
By loose blade I assume you mean that it can be moved up and down at the tip of the blade. It is most unlikely that the central nut has come loose, but check anyway. If this nut is tight and the shaft is loose in the bearing this means the bearing has worn out. Remove the deck from the machine. Photograph the run of the belt as this has to be removed. Also the direction of the grease nipple. Remove pulley from loose spindle. Turn deck on its edge or mount on two saw horses or similar so you can get to top and bottom of spindle bolts. Remove cutting blade. Remove spindle housing and clean area so no rubbish gets caught when reassembling. Otherwise spindle may be set different and mower will leave a line of differing cut. Take spindle to vise and remove any retaining nuts or circlips from shaft and clean as clean as new. Apply light oil or CRC etc to help move bearing along shaft. Open vise wider that outside of bearing, usually 44 to 50mm [1 3/4" to 2"] and refit nut on thread. Check nut is always spaced free of top bearing. With cushion of hardwood or nylon tap the shaft to move it down with lower bearing coming out of spindle housing. To remove top bearing from housing, turn housing up other way and use a wooden shaft such as a broom handle to tap bearing free of housing. Clean out grease and replace when reassembling. Do not reuse other bearing. They are cheap and likely to fail shortly anyway. These bearings usually have no seals on inside.
Sep 27, 2014 | Garden
Replacing bearinon spindle housing
Remove deck and place on two boxes or saw horses so that you can access both top and bottom of bolts holding spindle housing. Remove drive pulley from spindle. Remove cutting blade. Remove four bolts holding spindle housing to deck frame, noting which way grease nipple is pointing. Take spindle housing off and scrub deck frame clean of rust etc and also clean housing with wire brush. To remove bearings, look for retainers such as nuts or circlips. Remove these and ensure that the shaft is clean so bearing can be slid off. Apply CRC or light oil to assist bearing removal. Use a vise and set jaws wide enough that the bearing outside can fit between. This is usually 45 to 50mm. [1 3/4" to 2"] Place a hard wood block [or something that will not bruise the thread such as solid nylon] and screw nut well on to thread but make sure there is space for movement between nut and bearing. Firmly tap spindle end. Shaft should go down into top bearing and bottom bearing should start to emerge between vice jaws. Make sure that there is always space between nut and bearing before knocking end of shaft again. To knock top bearing out, place it on bottom over vise jaws and take a length of wood such as a section of broom handle and knock it out. Normally there should be no seals on the inside of these spindle bearings as they are greased from a grease gun thru the grease nipple.
Sep 26, 2014 | Garden
How do I replace the bearings on the mower deck spindle housing on my toro mx 5060
To replace spindle bearings: Remove deck and either rest on two saw horses or similar mounts, or stand on its side and fix to make safe and secure. Photograph the belt layout and also the grease nipple so you can easily refit.The object is to access the top and bottom of the spindle. Remove cutting blade. Remove pulley on top side. I reccomend that you also remove the spindle housing from the deck. You can remove bearings while still fitted but it is not so easy. Clean the shaft and remove any circlips or retaining nuts from spindle. Take the unit and clean shaft as clean as new. Use emery paper if necessary. Use light oil or CRC to lube the shaft to slide bearings off. Do not hold shaft in vise as this will cause deformation of the shaft surface and jam the bearing. Place lower side of housing on vise which should be open slightly more than bearing outer diameter. Take hardwood or industrial nylon [to protect the thread from bruising,] after refitting nut on shaft thread, and ensuring there is space between nut and bearing, tap down firmly with hammer. The shaft will move more easily after the initial freeing up. When it moves easily remove nut and tap down with wood between hammer and thread end. To remove the top bearing use a wooden shaft, a broom handle is ideal. The replacement bearings should have no seals on the inside. Remove if necessary. Make sure to scrub clean both housing end and deck where the housing fits. Any rubbish there will cause lines in the mowing as it can tilt the blades. The thickness of paper can mean 3mm at the end of the blades!
How do I remove the blade spindle from the spindle housing on the cutter deck of Mountfield 1436m lawn tractor?
I believe you have to remove the spindle housing then remove the snap ring, ( you may need to clean and scrape to locate the snap ring) from the inside of housing. Now you should be able to press the shaft from the housing. Or if necessary support housing with blocks so as to drive the shaft from the housing. I would spin the nut on the shaft, then place a piece of hardwood on the shaft and drive it out with a three pound sledge. There may be a snap ring for the shaft and one for the bearings. There may not be one for the shaft as it bolts to the pulley. At any rate this should accomplish you goal. There is usually a snap ring that retains the bearings, if this is what you need to replace.
May 08, 2014 | Garden
Wheel horse
TOMBONES49 is there anyway I can contact you or you contact me regarding a diagram you posted of a 1982 yamaha xt250 carb? I am currently going through one of these bikes and need to fine tune the carb but cannot find any info anywhere. You were the only diagram I found all over the net. My email is MarlinsMcnasty @ yahoo DOT com (figured the site wouldnt let me post it) or maybe reply on here? Im not exactly sure how to use this site but you seem to be the mechanic man!!! THANKS AND GOD BLESS
Apr 28, 2013 | Garden
Replacing the gear on makita angle grinder
Are you replacing both gears? The armature gear (pinion) is usually held on with a nut or else is pressed on. The spindle gear is also pressed on. Most spindle gears will come as an assembly with the gear and spindle and housing all together.
If yours doesn't, then the spindle will need to be pressed out of the housing, and then the gear pressed off of the spindle. (Always replace the grease as well when replacing gears.)
Mar 31, 2012 | Makita Saws
I would like to know if the wheel bearing is in the shaft or the hub?
The Constant Velocity (CV) joints are located on the inner and outer edges of the axle shaft. The axle shaft runs through the hub and bearing in the spindle.
Jun 16, 2010 | 1999 Daewoo Nubira
Craftsman 42in mower deck spindle breaks and Strips.
there are thousands of these mowers out there, and most people do not have the problem that you are experiencing - let's face reality, you are hitting something, that's the only way these break - it is impractical to make a machine that will mow through rocks, stumps, and water pipes and not break - also, sears does not MAKE anything, they contract companies to make products for them - if you want a thicker, tougher mandrel housing, log onto they recently began offering a heavy duty version of the mandrel housing, part no. 130794. i've seen these and they are definitely beefy - just be sure to put everything together correctly and tighten all the nuts and bolts firmly, and try to avoid the rocks and stumps
Jul 01, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
27 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
