Question about The Computers & Internet
I see nupgrade comes on my display of my dklink hd720 what can i do to solve the problem
I have ott tv box withe xbmc kodi 14.2 i have tried a number of times to nupgrade to 17.4 even with wookie help i got all my downloads back but now it wont load kodi
If you have a 1g 8G box then there is not enough memory to load anything newer than 16.1. Make sure you clear the build before you add one. I have found that Complete Kodi set up wizard helps a lot.You can find it on google play store.
Sep 06, 2017 | TV Box Televison & Video
Contact the manufacturer to see if there is a way to reset the account.
Nov 29, 2015 | AccessData Password Recovery Tool Kit (ftk...
Cubot P9 User Manual
There doesn't appear to be a manual Karen. Looked everywhere for one. You might find some help here:
Jan 16, 2014 | ahappydeal CUBOT M6589S Android 4.2 3G...
My phone is only letting make emergancey calls why
Could be you have no contact with your own provider. Could be you did not put in you pin.
Next time please put it in the correct category.
Dec 14, 2013 | ahappydeal CUBOT M6589S Android 4.2 3G...
Manual for cubot p9
I have dropped my phone. The screen looks cloudy but still works. Do i need a new screen?
Dec 12, 2013 | ahappydeal CUBOT M6589S Android 4.2 3G...
Come on screen but at that time when I press the menu all menu function come on screen but pc display not come. I change display cable & video board also but problem not solve.So, Pls. guide me. Thanks.
If again again display problem create then i suggest you change mother board and purchase own device supported mother board. If change mother board then display problem solved, but one step you change RAM may be your RAM device week and damage. So you first of all change RAM then finally change motherboard.
Oct 09, 2013 | LG 700M 17" CRT Monitor
My nokia N72 is not displaying when message comes nor it vibrates or rings .how to solve this problem
my nokia N72 is not displaying when message comes nor it vibrates or rings .how to solve this problem
Sep 28, 2010 | Nokia N72 Cellular Phone
My system display is not coming it does not display anthing
Try replace the Memory Module (RAM) with new ones, that's should fix the problems.
Feb 22, 2010 | Intel D915GAG Socket 775 Motherboard -...
Cd holder opening all the time
I don't know your specific model, but this problem is a common one. There is a loading belt that not only pulls the tray into the machine but also engages the cd onto the CD table with a clamping assembly. If the belt is starting to slip, it won't have enough grip to engage the clamper. This means that the load is unsuccessful and the unit will "eject" the CD. Have the loading belt replaced and all should be well.
Nov 06, 2009 | Harman Kardon HD720 CD Player
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
