Question about Yamaha Music
Hello dear yamaha psr e413 not work some button, i did carbon past. but not work. please help me. dear. Thank you.
    Uploaded 5 video answers.
  • Yamaha Expert
  • 128 Answers
Lets answer the question. Which button is not working? It normally means as suggested either the carbon under the rubber button is worn or in some cases the circuit board is damaged or worn. Try to replace the button first as the cheapest option. Report which button and I can send you details of the part number needed either by number on the attached or by which function it does eg tempo + / -
Hello dear yamaha psr e413 not work some button sw - psre413-wz3v4rllbsiyd0mxwjouzysu-1-0.jpg
Posted on May 03, 2017
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
  • 5603 Answers
SOURCE: MY Yamaha psr 550 stopped giving sound after
When cleaning buttons HOPEFULLY you did NOT use DeOxit or other contact cleaners like Blue Shower as these can damage the buttons that are conductive rubber.
The conductive rubber buttons should ONLY be cleaned with 99% isoprophyl alcohol and Q Tips. Both the conductive "pill" and the traces they contact on the circuit board should be gently cleaned with the Q Tip wetted with the alcohol.
If you used anything but the 99% isoprophyl alcohol, you can TRY cleaning properly and hopefully they will not have permanent damage.
Posted on Jul 17, 2010
  • 1138 Answers
SOURCE: faulty connection for AC power
If the adapter is faulty I recommend replacing it with the exact one for your keyboard. Any Yamaha music dealer should have one. If it is the jack in the keyboard that the adapter plugs into that is faulty it can be fixed. It is soldered to the circuit board and the solder joint has likely failed. You will have to carefully disassemble the case and maybe take the circuit board out if the solder side isn't accessible. Once you can see the solder joint wiggle the jack to see where the break is. You will need to resolder it. If the jack is broken ( the center pin in the jack sometimes breaks) you will have to desolder it and take it to a good electronics store to obtain the correct replacement and then solder it in.
Posted on Aug 24, 2010
Testimonial: "Thank you so much for taking the time to comment- you were absolutely right! "
  • 5603 Answers
SOURCE: Yamaha psr e313 can't switch on. The adapter is
Check that your power adapter is 12 volts DC AND MOST IMPORTANT is the center pin is positive... this is reversed of MANY adapters used for pedals, etc. The current rating should be around 1.5 amps. Don't take another techs word for it... check it yourself.
Posted on Sep 02, 2011
  • 1212 Answers
SOURCE: Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Posted on Mar 30, 2012
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Install PSR E413DRIVER
What driver do you want to install?
Jan 14, 2014 | Yamaha PSR-E413 Portable Keyboard
No power to the switch but will power up with batteries
One of two most common possibilities are a non-functioning AC adapter or keyboard AC adapter connector next to the Power On Switch has a cold solder joint and does not pass voltage.
Nov 04, 2013 | Yamaha PSR-E413 Portable Keyboard
Yamaha 9000pro, Ps is ok but unit will not boot
You may need to perform a factory reset operation. Turn power off, hold down the DEMO button and turn the keyboard back on. The
screen should display 'Setup is initialising'. This will disappear after a few seconds and the screen will display its default. If that does not work you may need to re-install program disks, I think you should have 6 of them
Sep 30, 2013 | Yamaha PSR-E413 Portable Keyboard
Yamaha psr 1000
I'm not sure I completely understand your problem sounds like you might be in "Fingered On Bass" mode. This means if you play a chord like F using the notes FAC- if you play them in 2nd inversion (so the order is CFA) the psr-1000 will make the note "C" the bass note. In this mode if you played ACF then "A" would be in the bass part. Change to "Fingered Chord"-this will enable you to play any chord with the tonic (the name of the chord) F whether you play FAC, ACF or CFA in the bass part. I don't have access to a psr-1000 but often with Yamaha instruments this can be changed by pressing and holding the "Auto Accompaniment" button. I hope this helps.
Aug 04, 2013 | Music
PSR E313 - I can't turn it on. For a while there I could turn on ok with the power button but it wouldn't turn off - I had to disconnect power source. Now the power button doesn't work at all. Tried...
Tom is probably right, the carbon contact on the switch wears out. Open the case and replace the switch.
Part #40
Price £ 3.95 + postage if required
Aug 03, 2013 | Yamaha PSR-E323 Keyboard
Dead keys yamaha psr e413 keyboard
Dead keys on Yamaha PSR e413 keyboard: Flip keyboard upside down, remove cover screws (use marked cardboard template to remember where they came out), spray suspect key-contacts with fast-drying contact cleaner, (usually a PCB with a matrix of contacts under keys), re-assemble base cover, wiggle faulty keys as far as possible to 'scrub' any dirt or oxidization. If this cleaning trick doesn't work, get a pro to check it.
Dec 08, 2012 | Yamaha PSRE413 Keyboard
Power comes on but the psr 9000 yamaha does not boot up past the first page
The unit probably is detecting an error during the power on test... A long shot MIGHT be a button or key that is stuck on, that is sensed as being pressed. See if all the buttons are completly up. If the unit has a harddrive, a failure of it can block the booting even though the operating software is not on the drive in these. If you find a button that is sticking, put a tiney bit of CRC226 around it with a Q tip. You can get the CRC226 in the electrical dept of Home Depot. You just want to wipe the edges of the button to lube it a bit.
Apr 11, 2011 | Yamaha PSR-E413 Portable Keyboard
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
Getting an error message when starting the PSR 2100
I would do a factory reset. Search Google for: factory reset PSR 2100.
It will be holding certain buttons or keys down when powering on.
Sep 18, 2009 | Yamaha Music
Music Logo
50 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Are you a Yamaha Music Expert? Answer questions, earn points and help others
