Question about Sony Playstation 3 (PS3) Console
Icons wont load
Controllers wont connect (reset them already) and the icons on the homepage wont appear.
You should try reseting your system video and audio settings : use the AV cables in your TV and turn the system on by HOLDING the ON;off button .
if this doesn't work, take the system to and support centre, must be a problem with your hardware .
else, try changing the Hard Disk to another one (must be a Sata 2,5'' 5400rpm)
Posted on Jul 26, 2009
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
My laptop starts up immediately, but wont go any further, i.e cant get desktop items, or any other programes
Heya
Start up menu and desktop icon doesn't appears because explorer.exe doesn't loads properly which is a system component file mandatory for the computer to load...Now the solution:-
Press CTRL+ALT+DEL simultaneously ONLY when you don't see any icons or the start up menu
Windows TASK MANAGER will appear.
Now click on FILE top left corner>>>NEW>>Type explorer.exe>>Click OK or enter
You will be able to see all the icons
I hope this fixes your problem,If it doesn't please reply
Thanks & Regards
LoNg liVe ThE GeeKs!!!!!
Dec 11, 2010 | Toshiba Satellite Pro L300D-EZ1001V...
I have installed the driver for my HP Photosmart 2575 (connected through usb) and when I try to scan a picture the following message appears: An error occured communicating with the scanner device. Please...
Ensure the cables are all securly positioned, Check that you have all icons pressent, if you only have 2 then it didnt install properly, if you have all 3 icons goto my computer right click, click properties and find device manager, click the (+) next to the universal serial bus controllers, right click the usb composite device entry and then click remove, disconnect the printer from the computer and then reconnect, the found new hardware should appear, click next through all of the pages and then click finish, if the problem persists try a different usb port.
Aug 12, 2010 | Office Equipment & Supplies
Icons and start menu in the computer doesn't work?
press control + Alt + Delete. go to task manager if you arent already sent there. Then go to File > New Task(Run..) and type: explorer.exe press OK
That should make the start menu and icons appear if this doesnt i suggest re-installing windows.
Hope this helps
Jan 26, 2010 | Microsoft Windows XP Home Edition
Missing some icons on website and my homepage
Hi rtwiedeman
This can be easily fixed.
When you are on the Internet,
From the Menu at the top
Go to Tools
Then Options
Then Contents
Check the box which says "load images automatically"
Click ok
When you come back to the page Just refresh it.
All the images and icons will be there.
Hope this will help you.
If it helped you, please give a rating
luciana44
Oct 01, 2009 | ViewSonic VX2235wm LCD Monitor
Can't see Network Icons in system tray, how do i fix this?
Just go to network connections. Right click on each connection and go to properties, And then select the check box which is related to displayin it on the task bar. That will sole ur problem. If it does, pls rate the answer. Thanks. Good Luck
Jun 26, 2009 | Microsoft Windows Vista Home Premium with...
Screen freezes.
I was fortunate to find the solution already posted on your site. Thank you for the assistance.
Apr 09, 2009 | SanDisk Sansa Connect MP3 Player
I try to log on but it wont show my desk top
I think you pc is virus infected...
try to restore if ..............
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
rate me ..
regards,
Nov 22, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Sansa Connect 4GB frozen screen during boot up
there is a recovery tool on the sansa website that you can download and it will fix your device but erase all of the memory and put back the original factory default settings.
Jan 22, 2008 | SanDisk Sansa Connect MP3 Player
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
