Question about Wap Vacuums
I have a wap vs600 wet & dry vacuum cleaner would like to know if I can use the vacuum without the paper filter bag for dry vacuuming
SOURCE: Miele Cat & Dog Vacuum
I have a Miele White Star. The Turbo Plus attachment has stopped working. Brush will not turn. I've had it all apart and cleaned it. Still a no go. Is there an electrical connection somewhere. Fixable or should I just replace it? Thanks Mary
Posted on May 23, 2007
reddevil6
  • 1673 Answers
SOURCE: My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Posted on Jan 09, 2008
reddevil6
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
SOURCE: USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The PB15 uses a fairly large pleaded paper filter for dry use, but it is an odd ball, as most of these type filters are held in place bay some sort of plate, and plastic nut. The PB15 uses a filter that has a bottom, and is pressed into place. For wet use, I would see if you can use the foam filter for one of the Craftsman small W/D vacs, like the old 2 gallon model, held in place with a rubber band, which is slipped over the cage with the float ball. It needs to be sealed across the bottom. That should cut down on spray making its way to the motor. The PB15 does have one good feature as the vacuum inlet has an elbow which keeps the water from being sucked straight into the motor intake, so the foam filter should do the job pretty well. I’d also look at the bag and rubber band that is used on some of the smaller Craftsman vacs, which sounds like what has been done on yours already. They are easy to find.
Because Genie no longer makes any vacuums or blowers, and did not keep a parts inventory to support owners of their products (a reason not to buy one of their garage door openers) it might be best in the long run to ‘garage sale’ the Genie, and buy a new vac from a brand that will be around for awhile. I have two Craftsmen, and one Ridgid, besides the PB15, which is going in the nest garage sale, for the above reason.
As far as your blower to vacuum problem -- The hose is moved from the blower outlet, which is the top black piece with the handle and switch, to the hole in the canister for vacuum. The intent of the PB15 was to use the top piece as a hand held electric leaf blower, or when attached to the yellow canister as a vacuum, when you use the hose attached to the canister.
Posted on May 06, 2009
  • 382 Answers
SOURCE: I need vacuum cleaner bags for a WST 1300
call a vacumn or small appliance repair shop most vacumn repair shops will know what bags you need esp if they service your model or may be able to tell you who to call
Posted on Dec 18, 2009
Testimonial: "Thanks, makes good sense."
When using a bag inside shop vac, do I still need to cover the motor with foam & paper & ring or can I leave those off?
Keep it on. The purpose is to give you something to clean, a time or two, rather than have to replace the more expensive filter. I know it seems redundant, but all of the pieces filter better than just a bag. Also, if the bag gets any damp or wet material, it breaks and your next filters are the foam and paper filter.
Feb 28, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I have a wap VS 600 combi cleaner and I've lost the manual, I don't know what I'm doing wrong in terms of switching the machine over to wet mode, I've done everything i could think of, please advise.
all wet pickup is a ball that floats when the water rises the ball floats to the top and plugs the vacuum hole shake the top if you here some thing moving thats the ball
Feb 11, 2011 | Wap 28538 Wet/Dry Vacuum
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Can you still get parts for a WAP older vacumn cleaner
Put the following into Google search:
Wap 28538 Wet/Dry Vacuum parts
I did and found a number of locations that say they sell parts for the vacuums. If you run into a problem, please let me know.
Sep 15, 2010 | Wap 28538 Wet/Dry Vacuum
Hoover core vacuum cleaner. My son has vacuumed water into machine. will this ruin it
Allow it to dry dry for sometime , clean all the filter after keeping it open, then run it open without any attachments , the bag or the filter till all traces of water/moisture goes off. I dont think there will much of problem unless it has gone into the motor and damaged, But take care if it is wet and allow it to dry before you touch it or connect to mains.
Aug 31, 2010 | Hoover Vacuums
Got a WAP wet and dry and the bag inside has split
Check with www.industrialvacs.com. They sell bags and filters for all Wap vacuums, including old ones. They also sell new Wap/Alto/Attix vacuums. The company is now a division of Nilfisk, from Denmark. If they don't have it, check with www.ultimategarage.com. They are also a stocking dealer for Wap.Good luck.
Mar 16, 2009 | Wap 28538 Wet/Dry Vacuum
Need filter
Check with www.ultimategarage.com or www.industrialvacs.com. They are both stocking dealers for Wap/Alto/Attix vacuums, now a part of Nilfisk of Denmark. Good luck
Mar 03, 2009 | Wap 28538 Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I have a 6 gallon shop wet or dry vac. The dust and dirt comes out around the base of the motor fin, not around the tank top. Now what? Oh I lost the filter around the drum that holds the ball, so I...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=765231
Generic problem for all Vacuums
I have a 6 gallon
Posted by tsfroggy on Jul 10, 2008
I have a 6 gallon shop wet or dry vac. The dust and dirt comes out around the base of the motor fin, not around the tank top. Now what? Oh I lost the filter around the drum that holds the ball, so I wrapped a rag around it and made it secure. Respectively: TOM
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The bag is not going to do the job as well as the filter around the drum that hold the ball. The filter that goes under the motor does a lot of the filtering or you would have to do some type of cage filter then a foam filter and then a paper bag, I f you have a cartridge filter then the paper bag can go over the cartridge filter , B4 you do anything – id you have some type of compressor – use it to blow out the dust and dirt out of the motor, then buy a cartridge filter and then a paper bad with a rubber band to hold it on. This will do the best filtering . Check with your local vacuum cleaner dealer and bring in the top of your shop vac so that they can fix a proper cartridge / paper bag filter – or the cage frame with a foam filter with a paper bag. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
Shop-Vac Corporation
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
My husband threw out my motor bag for my Delonghi Wet and dry M-31. Can I run the vacumm without this protecting the motor?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=538790
Delonghi Wet & Dry M-31
Posted by bcpercy on Apr 23, 2008
My husband threw out my motor bag for my Delonghi Wet and dry M-31. Can I run the vacuum without this protecting the motor?
No…. I would advise NOT running the machine without the filter because you will burn up the motor. You can use a paper bag with a rubber band to slide over the motor to protect it from dust and also if you have a foam type filter – you can put the foam filter on first, then the paper bag then the rubber band, or if you have a cartridge filter you can run it with just the cartridge filter bur would suggest cleaning the cartridge filter after each use – also you can place the paper bag method over the cartridge filter as well or call the Delonghi factory and order the part or they will direct you to a local dealer, Info listed below:
http://www.delonghi.com/Int/USA/menu.htm
Mailing address:
Fox International, LTD., Inc.
23600 Aurora Road
Bedford Heights, Ohio 44146
Customer Service – Sales 1-800-865-6330
Customer Service – Fax # 1-800-445-7991
Email: customerservice@delonghiusa.info
Email – Sales salesdept@fox-international.com
Business Hours
Monday thru Friday 8:30 am to 5:00 pm EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Vacuums Logo
Top Wap Vacuums Experts
ray gallant
Mai Lor
Are you a Wap Vacuum Expert? Answer questions, earn points and help others
