What is F2 problem on model w6441 - Washing Machines
W6441 Error message
google this with the model # and the brand along with the F4 error code
Jul 25, 2015 | Asko W6441 Front Load Washer
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Asko w6242
This may be the drain pump itself, it is common as I believe your model is fitted with a magnetic pump. If indeed this is the problem, the original pump housing can be used again by simply unscrewing, this will save money. You can buy pump assemblies in universal form most of the time but simply check that the housing fits to the new pump, most come with a choice of mounting brackets and have more than enough screw holes to suit most housings.
Jan 25, 2014 | Asko W6441 Front Load Washer
Can't download manual for W6441 washer
Here is the link for your manual you requested.
Manual
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Asko W6441 Front Load Washer
My Asko W6441 front load washer F3 message
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
Aug 28, 2009 | Asko W6441 Front Load Washer
ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
May 24, 2009 | Asko W6441 Front Load Washer
Asko washing machine has no power
check your ground fault interupters (outlets with butons) under the sink and around the kichen
then check the breakers in your breaker box
finaly call a sertified tecnition
Jan 22, 2009 | Asko W6441 Front Load Washer
f4 code is sapose to be the thermister, i'm looking for whosale parts supplyer can you help?
Mar 13, 2008 | Washing Machines
F3 Error Message
The F3 error code relates to a pump problem Check pump trap and clean. Good luck!
Aug 25, 2007 | Asko W6441 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
