Question about The Computers & Internet
The mining of L&H fre - The Computers & Internet
How to uninstall Adobe Air.
go to start
try going to the control panel
go to add or remove programs--see if it's there, it should be at the top, that's where mine is
across from the name should be remove--just click on it & it should remove
it from the computer
Apr 04, 2012 | Computers & Internet
My schiller at 102 is not charging and shuts off every time i attempt to print. Any ideas on what might be the problem?
hi,
One of the cause for this problem is the faulty backup battery. normally ecg machines runs on battery even if the power is connected. The power supply of ecg machines is meant for charging purpose only and doesn't have that much power to run the machine. also the companies will not recommend to take ecg at mines on condition.
First of all check the charging voltage is there or not. The battery charging voltage is 13.8v . check is the voltage is there at the pins of battery ,in mains on condition. If its ok the the battery have to be replaced. Normally the battery will be faulty.
ok
Feb 02, 2011 | RTO Schiller Cardiovit AT-102 w/ ECG and...
When i download yahoo it says no fre disk make 100 mb fre disk to download
Check what free space you have on your C: drive.
You need at least 3 to 4 GB of free space for windows to work properly.
Download and use CCleaner ( if you have windows XP, put a tick in the delete hottfix uninstallers), run the cleaner, the registry cleaner and then go to tools/ uninstall and delete as much as you can, all those programs you have not used in ages.
If you cant download due to lack of space, just goto control panel and find the uninstall programs, and delete stuff from there
Aug 30, 2010 | Intel Computers & Internet
Eveything freezes in the refrigerator non freezer compartment
THE T-STAT IN THE REF. IS STAING ON AND MAY NEED TO BE REPLACE OR THE DAPER CONTROL IS STAING OPEN. ON SOME OF THE OLDER MODLE YOU HAVE TO REPLACE THE ASSLY COME WITH FRE AND FRE, T-STAT DEFROST BORD AND DAPER. GOOD LUCK
Jul 16, 2009 | Frigidaire FSC23F7D Side by Side...
I bought a Sony SVO-9500 MDP VCR witout the manual, cannot get a manual anywhere!!! I wish to now the menu commands tPE SuH Cnr Ynr YEn FrE uIA FOT Please help, what do they mean!!!??? Thank...
Settings are described in the manual downloadable now at www.eserviceinfo.com
From the manual
tPE = tape end operation mode REwind/EJect/STop
SuH = SVideo selection AuTomatic/OFf
Cnr = Chroma noise reducer ON/OFf
Ynr = Digital luminance noise reducer ON/OFf
YEn = Digital Y enhancer ON/OFf
FrE = Freeze mode selection FRame / FIeld
uIA = VISS index marker ON/OFf
FOT = Foot Switch Operation LowEdge HighEdge LowLevel
Hope this helps
Mar 11, 2009 | Televison & Video
Nikon FE shutter speeds problem
I don't know, but it's worth a try. I took mine to the camera store, because my shutter wouldn't even work anymore, even with fresh batteries in it. He again tried new batteries, and turned the shutter speed knob from Automatic all the way over to "B" for Bulb, and back to the Auto. Guess What! I haven't used the camera in 3-5 years because I thought it was broke and going to need factory repair. Well, this tricked worked for me. I was so thrilled, because my daughter wanted some double exposures and special filters shots for her wedding. Also the weight of the camera I couldn't handle anymore with a health problem, so I went to digital, but would love a Nikon good digital.
Good Luck!
May 13, 2008 | Nikon FE 35mm SLR Camera
Shutter remains open
It may be fatal as there are no parts available for the FE series. The main components that cause this problem are the FRE/ASA unit and the meter itself. The FRE is located under the rewind knob side of the top cover. It is made of glass and can be damaged by impact. The meter is under the speed dial and can also cause this type of problem. Neither is a easy repair.
Nov 25, 2007 | Nikon FE 35mm SLR Camera
Viewfinder Distorted
it's sounding like a bad ccd imager, could be a connection problem however. if it is the imager it will most like cost more than it's worth to get it fixed. $200 to $250 ballpark.
Sep 17, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Computers & Internet Logo
21 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
