Question about Health & Beauty
Need to bypass remote as I don't have one for my wolf sunvision pro sf......
How do you get the glass off to replace bulbs
First, just pop off the colored strip along the entire canopy; mine is a burgundy looking color. This is just pressed into the groove on the flat side that is on the bottom of the strip on the top canopy. You can sometimes get it off with your fingers, but might need to get it started first with a flat head screwdriver. One you start getting it to lift up, the rest pulls off very easily. Then the metal piece on the side will just pop down or up (can't remember which) and then you can remove the curved acrylic by just putting a hand on each side and pulling it out towards you; It is not heavy, but it is big and bulky so it is easier with 2 people but can be done with just one person. I am female and I have removed mine several time by myself. My husband and I just recently replaced all of the bulbs in mine, facial tanner included. Good Luck. It really is easy once you know the tricks. Also, you can download the manual at http://www.docstoc.com/docs/87389135/Sunvision-Pro-24S-Tanning-Manualpdf---WolffTanningBedcom. Sunvision Pro 24S Tanning Manual pdf WolffTanningBed com . Good Luck!!!
Jul 12, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Sunvision tanning bed
REd + Black - and white common.
Feb 27, 2014 | Health & Beauty
I can't start the car in remote need to bypass clutch interlock switch how do I do that with out removeing plug. Remote is compatible for both automatic and manual transmission.Don not know what t
I do not recommend remote start systems for manual transmissions. You would have to bypass the clutch interlock to enable the starting circuit. If you left the vehicle in gear and used the remote you could do damage to the vehicle or other property (hopefully the parking brake holds the car in place). I have never seen a factory remote system on a manual transmission, to much liability....
Jan 01, 2013 | Cars & Trucks
What does the end of the cords look like on a sunvision 24 tanning bed
It should be like a big black power cord with a plug on one end.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Need info on changing fan motor on sunvision tanning bed
Sunquest repair manuel -
https://docs.google.com/viewer?a=v&q=cache:RHuta0rhh0UJ:www.wolfftanningbed.com/files/Sunvision%2520Pro%252024S%2520Tanning%2520Manual.pdf+&hl=en&gl=us&pid=bl&srcid=ADGEESiOZAyvaJoGk2XbMLNiN6HBrbcakHM2K0Ueegni817TYN8RJZmcoxwgkvEhbTnez0fQXKeYfAagL-vGcQOZe-_Lz1A8lISeW2omXte5lo7_wf0N6Ksg9heMx9RvHP7NvzHekFW_&sig=AHIEtbTIgYvCR-poN4KvkaVWUdCqD8mjDA&pli=1
Feb 05, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Health & Beauty Logo
59 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
