Error e5 on Godrej front load washing machine model no.GWI.5511 RES
Machine not working Massage on display e5
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
rdrsp
  • 85 Answers
SOURCE: LG model WM2277HW front load washing machine,
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
1) in my experience, sometimes this proves to be intermitent, and upon unplugging and waiting for 5 minutes does not seem to resurface again...
2)Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount.
this could prove to be very challenging to somebody who does not know what they are working with, i suggest if the problem is not intermitent, call a tech.. hope this helps.
Posted on Oct 26, 2009
jsrock516
  • 5911 Answers
SOURCE: my washing machine displays an f21 error on it
"F21" is a Long Drain error code which is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions.
NOTE: Maytag Epic is manufactured by Whirlpool, so these instructions do apply.
Posted on Apr 02, 2010
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
FRONT LOAD WASHING MACHINE GODREJ E03 ERROR
go to the manufactures website and download the user manual eric
Jan 04, 2018 | Washing Machines
Kenwood Model # KWM 7020FAF, Please note this washing machine is giving error E5, and we are unable to understand this error/ issue. please guide.
E5 unbalance load either put more item in are take some out unplug washer for 5 min should reset the code
Dec 18, 2017 | Washing Machines
When stachi do, not move clothes.
Godrej front load washing machine model no GWI5511 RES. Error e 5
Apr 20, 2017 | Washing Machines
My Nokia E5 code problem? What code?
Hello. What kind of code are you asking for your Nokia E5? If it is a network unlock code, you can get it from
http://www.prounlocking.com/nokia-e5/rs5wp9/ at affordable cost. good Luck.
.................UNLOCKING INSTRUCTIONS.................
  • 1 - Switch on your Nokia E5 without any sim card.
  • 2 - Don't bother as to what is displayed on your Nokia E5.
  • 3 - Compose #pw+CODE+1#.
  • 4 - The Nokia E5 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E5 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
  • 3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E5
Jan 24, 2015 | Nokia Cell Phones
How to unlock lock from Nokia e5-00
You mean the network lock?If so, I suggest you can approach Theunlockarena.com and specify the country,locked network of Nokia E5-00.based on the availability you can get the unlock code along with free instructions.
Oct 14, 2014 | Cell Phones
Error code E5
good morning my whirlpool washing machine is saying E5 and is not extract water from the pipe.. what can possibly be the problem
Sep 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
