Question about Kenmore Washing Machines
Kenmore top load washer fills won't wash or spin clickin noise around lid lights flash all of them
  • Kenmore Master
  • 3,197 Answers
My best advice...
Get on line with a SEARSPARTSDIRECT (below) person
and CHAT...
You need to remain insistent that you think it is your lid lock...
and that you want them to prove it to you... and help you replace it...
But only after you unplug the machine...
Fetch ot a good slap in the middle
where the DEFECTIVE Latch lives...
and plug it back in...
Once you get your part number... tell your chatter you are going to PRICE CHECK at \appliancepartspros, partsselect & repairclinic
before buying from anyone
(because they all sell the SAME "STUFF")
Water Filters Lawn Garden Appliance Parts
Posted on Apr 20, 2017
Jimster
  • 240 Answers
SOURCE: Kenmore Series 70 Washer Model 110
That would be your lid switch that has went bad.  Remove the console caps, then remove the two screws that hold it down (sometimes these screws are in the rear of the console)  Rotate the console out towards you gently, then fold it up and over the top of the unit.  You see 2 gold colored hold down clamps on top, and either side of the unit.  You will also see a wire and disconnect going down through the cabinet on your right hand side.  Disconnect these wires (be sure unit is unplugged) and rotate the whole cabinet towards you.  You remove the two screws that hold the switch in place and a 5/16" screw underneith that holds the ground wire.  Unclip the connector from the rear top of the cabinet and remove the switch.  Be sure to bring your whole model number 110.************** when you get the new part, there are two of these, and they look the same except the wire ends are different.  Good luck    Jim
Posted on Oct 17, 2007
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
mastatech
  • 478 Answers
SOURCE: We just purchased a top load Kenmore 800 washer
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a kenmore 90 super capacity top load washer
You can check your transmission if you like, but I think your problem is your lid switch. A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. You should not have to hold the switch closed with a screwdriver to get it to work. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Posted on Jul 08, 2009
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 15, 2011 | Kenmore Washing Machines
I have an elite kenmore top load washer. With the lid closed the washer will fill with water, but the wash or spin cycle will not start unless the lid is gently pushed down on the upper left side of the...
Lid switch has gone bad...
heatman101
Sep 22, 2010 | Kenmore Washing Machines
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
My model 80 top load kenmore washes but won't spin.
INSPECT LID SWITCH IT S WERE THE LID CLOSES SHOULD MAKE A CLICKING NOISE IF NOT IT NEEDS TO BE REPLACED
Jan 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
