Lcd appears on tv,not sure how to resume picture
Tv power cuts on power light lit no picture then Tv turns it self off, when picture appears there's waves in picture and tv turns itself back off and on with no picture just black scree
Hi Patty
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 14, 2015 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Sounds from tv when titles appear
U mean the tv have pictures flashes only a few sec. than dies have the tv pragram sound left only?Yes? Mean ur tv have a tv LCD Screen Panel have no tv LCD screen backlight to produce tv pictures tv now are having backlight problems.The tv have 1 or 2 long boards that are called LCD inverter boards problems and the causes.These 1 or 2 long Lcd inverter boards only job are to produced backlight for the tv LCD screen panel to hold on to give the tv screen panel to have pictures only.Tries websites like Shopjimmy.com,EBAY.COM to those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Oct 03, 2011 | Philips Televison & Video
My samsung le32r3bdx/xeu tv has vertical lines then the picture goes funny figures are metallic looking then picture dissapears (sometimes thick white vetical lines .when you switch it off normal picture...
That can be the T-CON baord or LCD panel problem.
You may want to try reseating the ribbon cables between the LCD panel and the T-CON board (delicate operation!), also the cable between the T-CON and the main board first.
See examples here:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Jul 18, 2011 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I have a 40" Toshiba
Any kind of black or colors lines on the tv LCD screen panel,not causes by u it appear by itself only can be repair by replacing the board that call the T-CON board.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy the refurbish T-CON board for the replacement.
Jun 24, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I recently purchased a 47"
Your TV has a light sensor that changes the brightness of the TV based on room brightness.
It's called an "Intelligent Sensor"
You can turn this off in your "Picture" settings.
Congrats on such a nice TV purchase.
If this was helpful, please rank me a 4.
Mar 09, 2011 | LG Televison & Video
MY SHARP LCD TV HAS PERFECT SOUND BUT WHEN WE TURN IT ON THERES NO PICTURE JUST RANDOM RED LINES.IF WE TURN IT ON AND OFF THEN THE PICTURE WILL EVENTUALLY RESUME
I don't have a solution, but the same thing happened to ours. To sidestep the problem, I just left it on 24/7. Eventually (three days ago) it just stopped working completely.
Dec 25, 2010 | Sharp LC-32SH12U TV
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Sharp LC-46SB54U Keeps losing picture intermittantly
i believe your tv is getting overheated, possibly from dust getting onto the electronic components inside. or the inverter board for the lcd panel inside is going bad, alot of times it is the capacitors on the lcd inverter board going bad.
Jun 12, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sound but no picture
it's the T-con board attached to the lcd panel
Jul 29, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
