Question about Cell Phones
My iphone wont turn on after charging it - Cell Phones
Iphone wont turn on
Hold the power button and home button down together for 10 seconds, or until you see a white apple.
Dec 07, 2013 | Apple iPhone Smartphone
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.
Second I would check to make sure the battery is actually charging.
Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
Jan 09, 2013 | Apple iPhone4 4G iPhone 4
My iphone is showing that it is charging but is stuck on 1%
Turn it off and plug it in to charge (do not turn it back on, it will turn on by itself).
Dec 24, 2012 | Apple iPhone 4S
My i phone wont turn on or charge
try cleaning your charging port.
Mar 22, 2010 | Apple iPhone Smartphone
My iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
Jul 28, 2009 | Apple iPhone Smartphone
My Iphone wont turn on
If you are comfortable with opening devices you can take a multimeter to the battery. If the phone doesn't turn on if you battery has 3.7V or more you have a logic board issue. Oh, did you do a hard reset yet? Press menu and sleep/wake button together for 5 sec. If after all revival attempts you still don't get it to turn on It's usually an issue with the logic board, so ultimately if you want to resolve it, the logic board needs to be replaced. There are iPhone Repair guides that show you how.
May 28, 2009 | Apple iPhone Smartphone
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
May 06, 2009 | Apple iPhone Smartphone
My iphone wont charge
please use a functional charger...
Feb 03, 2009 | Apple iPhone Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
