Question about Lands Phones
I have been phoning for a week bur can not get through to Springs number. Is the switchboard broken?
On the IP1NA-12TXH, pressed the call1 button and now the screen says switchboard. how do i go back to the regular name display?
If your phones says "switchboard" that is the name assigned to it. in idle condition you should have a name and an extension number as well as the time and day showing on your Aspire phone.
Oct 02, 2014 | NEC Lands Phones
Do I need to dial 9 before entering the telephone number
If you are a home user, then no. If you are in an office that has a switchboard and the fax uses an extension from the switchboard then yes ( it may on some systems be a 1 or a 3 instead of 9).
If you are in an office and the fax has its own line then again no. Its easier to just an ordinary phone into the socket and see which way works.
Jun 29, 2014 | Canon Pixma MX452
How do i find out what extension i am on?
If you have a KX-T7730 phone press the * button until it shows your extension number. If not, phone the switchboard operator (usually 10, 101 or 9) and ask the person what the number on the display is.
If this was helpfull please vote
Thanke you
Jan 18, 2010 | Panasonic KX-T7730 Corded Phone
Mitel 5220 ip phone (switchboard)
What phone system do you have?3300 need to call reroute first Alt. to other ext.
May 01, 2009 | Mitel 5220 IP Phone
Dear Sue Johnson
Right, well immediately you have given me a symptom of a fault with the LCD (Liquid Crystal Diode display), and my guess is that if the display is not liquid induced or that it is not broken, then the only thing left to rule rule out is power failure to that part of the circuitry. Now i would have tothoroughly investigate why this happened before i could pinpoint exactly what the fault is, but a good guess would be either bad refurbishment, or liquid induction/ ingression previously has damaged components.
Now about the extension problem, I wouldstart off by stating that the refurbed portion of the system may have malfunctioned again or even elsewhere on the device, which may or may not have been directly caused by refurbishing involvement.
Im guessing that either your switchboard controller is faulty, or possibly a fault somewhere in the switching equipment that is in direct relation to data transfer over the RJ45 connectors (standard phone/ network cable type connection)
Your best bet is to remove all of the phones on the extension/ switchboard and then install them one-by-one and see what errors are thrown up, the ones that cause you a problem and then tackle the switchboard with the direct fault.
If all of this is to do with the phone (s) and not the switchboard, then i would say, remove the phones, replace them with a similar type and then notify someone like myself who may be able to advice you on your next best course of action. But if yor phone network is that valuable, then i strongly suggest selling the broken phones for spares / repairs and using the money to at least cover part of the cost of purchasing new ones of the same make and model as the ones on the rest of your local system.
The same will obviously apply to the switchboard, unless there are user servicable components inside, or you are particularly handy with electronics, comms technology and a soldering iron.
In the mean time, I wish you all of the best luck, and I hope to hear more about this situation soon, I also look forward to helping you the best i can with regards to this matter.
Yours sincerely
Im logged on here 24hrs 7/365 days year now, so if you need advice, then im only a click and a few questions/ comments away
Apr 10, 2008 | NorStar BCM-T7208 Corded Phone
Same problem no answer as of yet
Jun 05, 2007 | Emerson Switchboard Deluxe Phone Line...
Lands Phones Logo
27 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
