Question about Sharp Televison & Video
Sharp 60 in aquos won't turn on.if I unplug it and plug it back in the v lights up for about 5 sec then turns off again I have 5v standby power
highspeedsan
  • 61 Answers
SOURCE: sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
Posted on Apr 30, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
  • 8457 Answers
SOURCE: Sharp AQUOS LC-26P50E television. Stuck on 'Standby'/'Sleep'
Ur power ic inverter board is dead.
U need a new one.This prob.very comon with SharpThe Sharp corp. is a joke,never release much of this part for sale.It almost imposible to find it.
Posted on Sep 05, 2009
  • 4 Answers
SOURCE: aquos 42 won't turn on
Try unpluging it for 30 seconds and plug it back in. This is how some electronics are reset.
Posted on Dec 30, 2009
  • 8457 Answers
SOURCE: my sharp aquos lc-32p55e tv.When u swith it on it
Ur power board have dead parts,Check parts like Capacitors puff up or burst open.Know how to solder?Or replaced the the whole power board,Websites Shopjimmy.com,Ebay.com have reburbish power board.
Posted on Jan 13, 2010
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
Hi I have a Sharp aquos tv that won't turn but does weird things. is there an easy diy way to fix this.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 17, 2015 | Sharp AQUOS LC-60LE820UN 60 inch LED HDTV
My Sharp 60 in Aquos will not come on. The power light in the bottom Right hand corner is not on either.
Unplug, press power a few times and plug back in and try, power outtages can get the standby power stuck.
Jan 15, 2015 | Sharp Televison & Video
Sharp aquos will not turn on
The Power controll board is likely bad.
Dec 29, 2014 | Sharp AQUOS LC-50LE440U 50" LED TV...
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Nov 06, 2009 | Televison & Video
Sharp aquos won't turn on
Any indicator lights on, if it is then you only have the standby 5v circuit working, you will need to have the power supply check out first, that is a starting point.
Oct 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos Won't Power On
I have the same problem with my My LC-42D62U WHen i watch certain DVDs, (so far it happened on SAW III and RUNNING SCARED) during certain parts of those movies my TV will turn off and i cant turn it back on unless i unplug it and plug it back in. It only turns off on specific parts in the movie, i have no idea why...like the same exact parts...so i pretty much have to pause the movie with my remote once my TV turns off then when i power the TV on again just resume the movie and its fine...but if i rewind to that part again it'll power off again SAW III only had one part like that....but RUNNING SCARED had about 3-4
Apr 09, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Televison & Video Logo
53 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
