I have a navman5500.It's not picking up any GPS signal.I've fitted a new aerial,still no reception,I was wondering if it was the way I've wired it I bought it second hand and had no wiring diagram.
mixmaster
  • 626 Answers
SOURCE: wiring diagram
Manual is here; http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-4021~3021~306~2092%20(EN).pdf Page 23 has the wiring info. Best of Luck.
Posted on Sep 26, 2007
Testimonial: "Thank you very much for your help, job now done."
physicistFL
  • 34 Answers
SOURCE: furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below.  It should be simple to wire up.  You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Posted on Jan 07, 2009
  • 5 Answers
SOURCE: My new TomTom One XL will not pick up a GPS signal.
Well, it MAY help to download the tomtomhome program from the tomtom website, then connect your unit to your computer and update, including the gpsfix application (that's for all the other posters who didn't mention having updated). But for Drakeca05, updating MAY have been what messed you up in the first place. I updated two days ago with tomtomhome--my tomtom one was working fine, but was a little slow to initially acquire satellites. Now since the update it's even slower, sometimes won't acquire them at all, and randomly drops them. Tomtom tech assistance is useless--they just refer you to the standard "acquiring satellites" faq that you can easily find yourself on their site & nothing there is the least bit helpful for this.
Posted on Mar 20, 2009
  • 31 Answers
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Posted on Aug 16, 2009
  • 239 Answers
SOURCE: audio wiring diagram for an irish corolla verso
2005 Toyota Corolla Car Stereo Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Power Antenna Wire: Black
Front Speaker Size: n/a
Front Speaker Location: n/a
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: n/a
Rear Speaker Location: n/a
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
pls rate
Posted on Aug 18, 2010
Quasar television radio combo. ANY way to get channels without a buying a converter. It has screw connections that looks like you are to use some type of uhf transformer type thing. I do not have any of...
I haven't heard of a radio/tv combo since the demise of vhf tv.
A reasonable radio reception could be derived from the vhf tv signal making a usable unit without the bother of an additional aerial. For use with uhf tv the radio would probably need an additional aerial for decent fm radio reception - unless the radio is am only...
You don't say how old your combo is or give any details. I think the screw terminals could be intended to be connected to a 300 ohm balanced dipole aerial for radio reception only or to mount a loop aerial for indoor tv reception only, if the tv is intended for uhf analogue reception.
If the tv isn't equipped with a standard socket for the usual 75 ohm coaxial type aerial lead it is possible the set manufacturer originally supplied an adaptor to fit to those two screws in order to provide a regular aerial socket.
Without a much more detailed description, these are the only comments I am able to make.
Apr 02, 2018 | Quasar Televison & Video
Toyota corolla professional aerial problem, reception on radio
Some tints have metal in them so it might cause you grief but how is the radio when you wind down the windows ?
A power aerial might fix the problem put in the front fender and then run to the radio via a coaxial cable.
However in my car it was the radio that was the cause of the same bad reception and it worked on one channel only.
I have since replaced the radio but this may not be the cause of your problem and you would want to really know if the radio was the cause before incurring an expense of a new car radio.
May 28, 2017 | Cars & Trucks
I just installed a new Sony XT-100HD HD Radio Tuner for my truck. I wanted it so i could pick up more stations and have them all sound clear. After I hooked everything up to see if it worked all I could...
It is always worth checking the aerial in any case of poor reception.
In the case of a standard mast-type aerial it is necessary for the mast to have very good continuity to the centre of the aerial plug, that the outer part of the aerial plug has good continuity to the aerial ground and thus to the vehicle bodywork and the two parts are electrically isolated from each other. A good independent radio ground connection also helps.
In the case of miniature aerials or those within a windscreen, a rear screen or rear quarter glass, the amount of signal available will be small and so an aerial preamplifier will be provided to boost the signal. The preamp might be part of the aerial or a separate unit fitted anywhere convenient. I once found one fixed to the front firewall behind the dashboard.
The preamp needs a good 12 volt supply and a ground as well as good connections to the aerial coaxial leads. The supply is usually obtained from the radio set so it is operative only when the radio is switched on. Sometimes a radio has a dedicated output but mostly the electric (automatic) aerial output must be used. If the preamp isn't working reception will typically be limited to a few powerful stations.
I hope this helps.
Oct 21, 2017 | Sony XT-100HD HD Radio Tuner
I get poor reception and wonder if there's a way to boost TV reception.
There are aerial boosters but they not only boost the aerial signal but the noise as well. Some work, some don't. The best option is a new aerial and cable.
Feb 10, 2011 | Televison & Video
Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Apr 06, 2010 | Kenwood KR-V7080 Receiver
I have just moved house to Reading and previously was able to view freeview tv using my old indoor aerial in my 2nd floor flat in london. This indoor aerial didn't pick up any signals, not even analogue,...
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
I have recently moved areas. my toshiba regza 37'' does not tune into the free view chaneels everytime. even when it does the quality is awful. sometimes it does not tune into the bbc related channels....
The most likely problem is the aerial system you are using in your new location. It could be either the position of the aerial needs to be adjusted or the cable coming from the aerial has a problem, check the end connector that goes into the Tv to make sure it is wired correctly. Also check with your new neighbours to find out what quality of reception they have, it's possible you may in a "weak" zone for picking up a freeview signal.
Aug 24, 2009 | Televison & Video
Unable to get satellite reception
Make sure you are not moving and that you are on an open field with minimal aerial hindrances. It takes time for the GPS unit to acquire satellite signal and makes it difficult to acquire when you are moving so make sure you stop at an open are till it syncs with at least 3 satellites.
hope this helps!
-levibit-
Mar 20, 2009 | Garmin Nuvi 350 Car GPS Receiver
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
New aerial wont pick up digital reception and fuzzy picture on terrestrial channels
Hi.
If you put aerial up your self was it wide band aerial ?
Is it in the atic or on the roof ?
Have you used decent quality cable (not the cheap stuff)
How long is cable run from aerial ?
Have you checked that when you fitted rf plugs that none of the braid strands are touching solid copper inner core ?
Ask an earial installer or Tv shop what the signal strength is like in your area.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
